I have an avi file with 2 audio tracks.
I converted from avi to dvd, but the 2nd audio stream is not there.
The original file does have both streams and it will play.
I used Dvdvideosoft ( which I have used in the past with no problems.)
Any help appreciated.
Does it support two audio streams???
If not use something that does like convertxtodvd. -
Thanks for reply.
I have always used it and had no problems in conversion.
As I said, the avi file (original) does show both streams.
I will give your suggestion a try.
Thanks -
Also avstodvd and multiavchd are other possibilities.
Also do these audio tracks meet dvd requirements? Does your conversion software that you were using always convert the audio to dvd specs? If its out of spec it has to be converted to be read as a normal dvd soundtrack. And it has to support multiple audio tracks as previously mentioned (the authoring/conversion software that is).Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
AVI to MPG Conversion Audio Problem - please help!
By Nuzy in forum Video ConversionReplies: 4Last Post: 17th Nov 2010, 22:34 -
problem with conversion from DV-AVI to DVD
By obadvw in forum Video ConversionReplies: 1Last Post: 24th Jun 2009, 17:08 -
MPEG-2 528x576 to AVI conversion problem.
By madman1987 in forum Video ConversionReplies: 7Last Post: 3rd Feb 2009, 10:53 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50 -
Joined avi file conversion problem
By siberian50 in forum MacReplies: 12Last Post: 26th May 2007, 19:04
