Hi there,
I was wondering if there was a way to transferring few films already recorded on my DVR (swisscom) box to my PC / Laptop.
DVR (encrypted) --> PC / Laptop??
I am advised that the recorded films on DVR are in encrypted form. The DVR box looks like this - http://www.swisscom.ch/fxres/asp/tv/img/box/SetupBox_plus_hinten_PopUp_en.jpg
I wanted to know the different ways of doing this.
secondly , someone suggested connecting DVR to DVD recorder (via scart) and then to burn DVDs instead of copying media directly to PC from DVR, not sure if this works on encrypted films?
DVR (encrypted) --> DVD Recorder --> PC / Laptop ??
Any guidance on this will be gratefully received
Please note that I am non technical person and at a beginner level, so please provide as much instruction as you can.
many thanks
I haven't seen any crack for the 5C encryption used by DVRs. Whether the analog route works will depend on whether the DVR applies Macrovision to its output and whether the DVD recorder responds to it. You can use a "video clarifier" to remove the macrovision signal. If your PVR has component outputs you can record HD material with that and a Hauppauge HD PVR.
sorry, what does component output mean?
In summary, does it mean that there is no solution available at the moment?
http://en.wikipedia.org/wiki/Component_video
As far as I know there is no way to copy 5C encrypted video off a PVR digitally. If you find a way please post the details. -
Were it a tivo DVR, tivo provides an application to offload via a network cable.
Otherwise, you'll have to go the DVD recorder or capture card route.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep"
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Newbie with a question about transferring from V+ box to Sony RDR-HXD 995
By Philbert in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2010, 04:19 -
Beginner needs help transferring DVR recording to computer
By kimatthedock in forum DVB / IPTVReplies: 1Last Post: 30th Aug 2009, 21:37 -
Transferring DVR files to laptop
By billiejean in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2009, 14:17 -
Transferring from a DirecTV DVR to Computer?
By Hangrumps in forum Capturing and VCRReplies: 0Last Post: 19th Dec 2008, 13:26
