    Jan 2011
    herre
    last time x264 was shutting down this time picture is not only pixelated but FPS speed is very slow @ I7 processor normalny i have 50-80 now i have 23-31
    what i can change in settings more? all codec settings in inspector are ok . Previous version was working ok then i didnt used rebuilder for 1 1/2 months.
    snap shot isnt done propelry in backgorund there is picture but its looks like one big watefall .
  2. It sounds like your CPU is overheating and throttling back. And still getting errors. Check the CPU temperature. If it's high check the CPU fan and case fans.
    Jan 2011
    herre
    this picture is wrong created but i unchecked few options in Rebuilder and picture was properly crypted. No i am not using overclocking too I7 is fair enough for BD compression but tomorrow i will be checking after burning on RE disc thanks for help/answer anyway
    there is mentioned that rebuilder is doin also MKV where is this option?
