Ok here is my question. Could the in-movie experience disc icon that is displayed on bluray and hd-dvd movies lead to burn-in issues?
I have started watching some of my hd-dvd movies with the in-movie icon with my hd-dvd drive for my xbox 360. I'm disappointed the disc icon appears to stay on screen during the whole movie. This happens on my matrix trilogy I have on hd-dvd as well as the Matrix reloaded disc I have on bluray (yes I rebought a matrix movie on bluray even though I have the hd-dvd trilogy box set - for some damn reason the reloaded disc refuses to be recognized in my xbox hd-dvd add on drive hence the reason I bought it again on bluray).
Now on my ps3 I have it connected via hdmi and I have the zoom feature available on my hdtv set. So long term if icon burn-in is possible I can simply use the overscan feature of my hdtv. It crops the hell out of the nice widescreen movie but at least I can still see the pop up videos during the in-movie experience session.
The trouble is my xbox is connected via the vga input. I cannot use my tvs zoom feature for some reason on this input mode. Nor does the normal xbox 360 zoom interface work with the hd-dvd drive. It does have a player zoom feature but so far as I know it will not let you watch a whole movie while zoomed - I believe it has some time limit and then it goes back to oar.
So is this a concern? The movies I want to watch with the in-movie experience are all around two hours or longer. I don't want to risk screen burn in.
Fyi the set is a 60 hz 32" lcd by westinghouse (1366x768 native resolution).
Am I worrying about nothing?
Last night when I was watching the first matrix with the in-movie experience I made sure I flipped to my cable dvr every ten minutes or so for a minute at a time to avoid possible burn in.
I can look up my tv model number if that would provide more detail on whether or not my set is susceptible to burn-in at all.
Your insight is appreciated. Thanks.
Also if anyone knows of a way to get rid of that damn disc icon while playing the in-movie experience on either an xbox 360 or ps3 please let me know.
I've been toying with the idea of capturing the in-movie experience with my hdpvr and then reencode with a black mask over the top of the black bars but that would take a lot of time. I'm also not sure how to cover a black border and maintain the aspect ratio and what I would use to reencode that while keeping hd - would multiavchd have a masking feature to reencode the h264 from a hauppauge hdpvr and keep the high def but block out the damn icon?
LCD displays don't suffer from burn in.
Even if they did, encoding a black mask over the icon wouldn't help. It would cause anti burn in. Burn in is a problem limited to devices with phosphors. The more they are used the less light they put out. Overwriting with a black box would cause the phosphors in the box to age less slowly than the rest of the display. So you would get a bright burned in pattern, not a dark one.Last edited by jagabo; 26th Feb 2011 at 08:27.
I did not know that.Originally Posted by jagabo
Interesting. So that would have the opposite effect I was looking for.Originally Posted by jagabo
So on a lcd set I don't have to worry about the little icon staying in the same place for two hours then? Thanks jagabo.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
That's one of the benefits of LCD over Plasmas! I have both and while each has their pros/cons, I like my LCD better. On my Plasma, I can see ghost images of the PS3 main screen after only 5 mins! While it does go away, I'm afraid it may suffer from burn-in eventually.
Thanks jagabo and mrswla.
Would it be possible to make a 3dtv preamp for 60hz hdtv sets?
By yoda313 in forum Newbie / General discussionsReplies: 8Last Post: 16th Dec 2010, 21:36 -
Laptop to LCD HDTV--Screen Size issues on TV
By blackdog69 in forum DVB / IPTVReplies: 7Last Post: 13th Oct 2008, 17:35 -
How to convert a HDDVD-movie to Blu-Ray and burn it ???
By kulmagen in forum DVD RippingReplies: 3Last Post: 11th Feb 2008, 23:57 -
BluRay/HDDVD Authoring
By The Sumerian in forum Authoring (DVD)Replies: 4Last Post: 14th Nov 2007, 12:13 -
HDDVD/BluRay and x264+Matroska?
By BIOHazard87 in forum Newbie / General discussionsReplies: 10Last Post: 3rd Nov 2007, 04:41
