Hello,
I recorded an excerpt of an HD tv program. It's in MPEG TS.
I was looking for some help : what do you use to demux it and cut directly video ?
My problem is ProjectX doesn't have enough memory to display frames, so I can't see where I need to put the cut, furthermore, it doesn't want to output something.
What software would you use in that case ?
Thanks in advance !
Results 1 to 10 of 10
Ok thank you very much !
So I have tested all except videoredo and TSdoctor.
TsMuxer doesn't take anything else than video.
TSSniper demux everything (VLC can't get the audio, but Windows Media Player can, wtf ?), without subs.
TsRemux can't output a correct file.
H264TS_Cutter can't open any file
ProjectX demux only audio/subs.
It seems I can make something not bad.
But I discovered DGAVCDec, it seems it decode correctly ! -
Ok, I really don't know why it fails sync audio and video when I mux it into MKV : video go fast and slow down frequently.
I'm trying with Avidemux.
Any idea for this problem ?
Edit:
I don't know I tried two demuxers and two muxers.
Avidemux gaves an awful video, unwatchable.Last edited by Liss0; 26th Feb 2011 at 10:29.
Ok, the original file non-muxed-demuxed :
The cut Mpeg TS with TSSniper :Format : MPEG-TS
FileSize/String : 4,87 Gio
Duration/String : 1h 24mn
OverallBitRate/String : 8 202 Kbps
Vidéo
ID/String : 720 (0x2D0)
MenuID/String : 1031 (0x407)
Format : AVC
Format_Profile : Main@L4.0
Format_Settings_CABAC/String : Oui
Format_Settings_RefFrames/String : 4 images
BitRate/String : 7 120 Kbps
Width/String : 1 440 pixels
Height/String : 1 080 pixels
DisplayAspectRatio/String : 16/9
FrameRate/String : 25,000 Im/s
Resolution/String : 8 bits
Colorimetry : 4:2:0
ScanType/String : Entrelacé
Bits-(Pixel*Frame) : 0.183
StreamSize/String : 4,23 Gio (87%)
Coordonnées de chromaticité : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Charactéristiques du transfert : BT.709-5, BT.1361
Coefficients de la matrice : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
ID/String : 730 (0x2DA)
Format : MPEG Audio
Format_Version : Version 1
Format_Profile : Layer 2
BitRate_Mode/String : Constant
BitRate/String : 256 Kbps
Channel(s)/String : 2 canaux
SamplingRate/String : 48,0 KHz
Video_Delay/String : -864ms
StreamSize/String : 156 Mio (3%)
Language/String : Français
Audio #2
ID/String : 731 (0x2DB)
Format : MPEG Audio
Video_Delay/String : -840ms
Language/String : Allemand
Texte #1
ID/String : 740 (0x2E4)
Format : DVB Subtitles
Texte #2
ID/String : 741 (0x2E5)
Texte #3
ID/String : 742 (0x2E6)
Menu
ID/String : 710 (0x2C6)
List/String : 720 (0x2D0) (AVC) / 730 (0x2DA) (MPEG Audio, Français) / 731 (0x2DB) (MPEG Audio, Allemand) / 740 (0x2E4) (DVB Subtitles, Français) / 741 (0x2E5) (DVB Subtitles, Allemand) / 742 (0x2E6) (DVB Subtitles, Français)
The Demuxed video file with dgavdec :Format : MPEG-TS
Taille du fichier : 4,42 Gio
Durée : 1h 17mn
Débit global moyen : 8 149 Kbps
Vidéo
ID de menu : 1031 (0x407)
Format : AVC
Profil du format : Main@L4.0
Paramètres du format, CABAC : Oui
Paramètres du format, RefFrames : 4 images
Durée : 1h 17mn
Débit : 7 072 Kbps
Largeur : 1 440 pixels
Hauteur : 1 080 pixels
Format à l'écran : 16/9
Images par seconde : 25,000 Im/s
Résolution : 8 bits
Colorimétrie : 4:2:0
Type d'image : Entrelacé
Bits/(Pixel*Image) : 0.182
Taille du flux : 3,83 Gio (87%)
Audio #1
Format : MPEG Audio
Version du format : Version 1
Profil du format : Layer 2
Durée : 1h 17mn
Type de débit : Constant
Débit : 256 Kbps
Canaux : 2 canaux
Echantillonnage : 48,0 KHz
Delai par rapport Vidéo : 15ms
Taille du flux : 142 Mio (3%)
Langue : Français
Langue, plus d'info : Clean effects
Audio #2
Format : MPEG Audio
Durée : 1h 17mn
Débit : 256 Kbps
Canaux : 2 canaux
Delai par rapport Vidéo : 39ms
Langue : Allemand
Thank you very muchFormat : AVC
Taille du fichier : 4,02 Gio
Vidéo
Format : AVC
Résolution : 8 bits
Edit : I'll try this way : demux with dcavdec and split it later (i'll try to see if the TS file is not corrupted : just saw "there is a detection of a different audio codec than announced" :-° ).Last edited by Liss0; 26th Feb 2011 at 13:15.
I did another test : recording with my Tuner TV card.
And it appears, it works very well. Muxing in MKV after Demuxing (and there's a lot of video tracks due to the transponder).
So I guess it comes from the Freebox HD (a DVB-T Recorder).
Any idea to fix this ?
P.S. What do the professional of video-editing use ? (I don't see them working on lots of free and open-sourced switching between them from time to time...) -
Wow ! Now it sync perfectly.
I'll try on bigger video files (I lost lot of time doing this on 2h movie :P ).
Now, I demux the video with DGAVDEC and use MediaCoder then mkvmerge. Avidemux seems to have some decoding problems (errors...).
I'll check this out deeper.
Thank you very much !
3D dvd content - convert to Blu3D content
By Smells_Like_Feet in forum Authoring (Blu-ray)Replies: 19Last Post: 18th May 2011, 07:52 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35 -
Content
By stompinne in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2007, 12:18
