I'm having this problem with XMedia Recode (just upgraded to the latest version as I've had the same problem with previous versions). I'm trying to rencode a video which skips or stutters every couple of second or so. Here's the file info.
Format : MPEG-PS
File size : 10.0 GiB
Duration : 1h 45mn
Overall bit rate : 13.7 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=15
Duration : 1h 45mn
Bit rate mode : Variable
Bit rate : 13.0 Mbps
Nominal bit rate : 18.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.209
Stream size : 9.55 GiB (95%)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Duration : 1h 45mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Video delay : -486ms
Stream size : 288 MiB (3%)
Here's the settings I used for XMedia.
Format - mkv
Codec - MPEG4 AVC / H.264
Profile - high
Level - 5.1
Framerate - 23.976
Rate control Mode - avg bitrate
Bitrate - 5000
All other video settings are left at default and there is no audio encoding. I am also leaving the resolution the same.
This is a file I've transferred over from TIVO (already decoded w/ a different program). Seems every file I transfer over from TIVO this happens with. Only reason I would think this is happening is because I am changing the framerate from 29.970 to 23.976. I would do another encode leaving the framerate alone but each file takes appx 24 hrs. Any suggestions? Thanks.
Think about it. You are throwing away 6 frames every second. That is 20% of your frames. Of course this is going to have a detrimental effect.
If your source was originally 23.976 fps then you might be able to IVTC it back to 23.976 and get smooth playback. But if it was shot at 29.970 fps, then you have to encode it at 29.970 fps.Read my blog here.
XMedia Recode problem: No audio !
By penang in forum Newbie / General discussionsReplies: 12Last Post: 17th Mar 2012, 00:29 -
XMedia Recode Problem
By Myrdivar in forum Video ConversionReplies: 2Last Post: 30th Aug 2011, 03:57 -
No video preview with Xmedia Recode?
By smackyourfupa in forum Video ConversionReplies: 10Last Post: 2nd Jul 2011, 18:44 -
XMedia Recode v 2.2.1.6
By Bonie81 in forum Video ConversionReplies: 2Last Post: 4th Jun 2011, 14:19 -
Xmedia Recode V. 2.25.8
By pepegot1 in forum Video ConversionReplies: 20Last Post: 29th Aug 2010, 23:58
