i am very new to all of this. i would appreciate if someone could answer me this.
i am about to (try) and setup a wireless network at home.
firstly i have a netgear (a/b/g) wireless adsl modem router which i am using with my
laptop HP Pavilion DV9260US.all of this is working fine.
i would also like to have an internal network and have purchased a
D-Link DIR 655 N router
D-Link 643 Xtreme N Notebook Express Card
D-Link Range Booster wireless DWA-140 adapter
my question is if i cable connect my netgear adsl modem-router to the D-Link DIR 655 N router
can i maintain my present internet wifi connection using my laptops internal (G) wifi card simultaneously operating an internal network thru the dir 655 router and the 643 express card
and the d-link 140 usb adapter connected to my wdtv live.
would there be any conflict.
even if this is all possible i have no idea at that point on how to go about setting it up bhut first things first.
like i mentioned i am very new to this so forgive me if i havnt explained my self properly.
any help or suggestions would be very much appreciated.
Thread: setting up an internal netwok
Connect the new router to the old one with a LAN connection, not the WAN one. Then the new router should act as a switch and pass on the data. The new router should be able to output a signal on the 'N' band. You do have to be careful not to use the same LAN addresses on both routers or you will have conflicts. You can set up the old router with fixed addresses and use different fixed addresses with the new router.
hi
many thanks for the speedy reply. i am really happy to know that i can use both the internal laptop wifi card and the express card wifi adapter at the same time.
i have read somewhere that ( i will have to search it out again)
if there are conflicts in the addresses i can modify them by cable connecting my computer to one or both of the routers to change it. is that correct?
many thanks for your assistance
MKV with Internal Subs ??
By zenzen1 in forum Video ConversionReplies: 3Last Post: 28th Aug 2009, 09:54 -
Internal vs. External ripping
By hardy in forum Newbie / General discussionsReplies: 9Last Post: 27th Jun 2009, 12:32 -
Which of the FOUR internal DVD burners is best ?
By MacPCConsultants in forum DVD & Blu-ray WritersReplies: 40Last Post: 29th Nov 2007, 22:56 -
External x Internal HD
By fjmr in forum ComputerReplies: 7Last Post: 21st Oct 2007, 18:12 -
internal hard drive
By LFC 1304 in forum ComputerReplies: 3Last Post: 4th Jun 2007, 12:37
