Hello all-
I am wanting to simply break a movie into parts for the individual scenes. In the past I have used vdub, tmpgenc or womble mpeg wizard software to do pretty much any editing. The file that I am currently trying to edit plays fine on VLC and MPC. The properties of the video file are shown as WVC1 on MPC player and VLC player.
When I try and open the file in any editing software I get an error message saying that it is not a supported file or the codec is not installed. When I run the file in gspot it says the codec cannot be determined for the video. The audio is AC1. I also tried using Cut Assistant and WMencoder software because of some info I read online. Same problem. Cannot open the file.
Anyone have a suggestion on editing the file? Do I need to install another codec even though the files play fine? If so, how do I locate the correct codec?
 I tried to install asfbin twice but i get an error that says the installation configuration could not be completed and to try again. Same thing twice.
 Movica requires the .NET framework to be installed and I don't want to do that. I installed that on an older computer of mine and it screwed up all kinds of stuff. I think it had to do with Image Grabber II if I recall correctly.
 Thanks for the suggestions anyway.Last edited by ezzeee1; 25th Feb 2011 at 19:46.
 Well here is the error I get with asfbin. They describe it as an installation problem.
 I got the file to open in Movie Maker, now I just need to figure out how it works.
 Thanks for the help.
	I got it done! Yeah!
 I opened the file in Movie Maker which apparently installed a codec. When that happened I was able to open the file in WMEncoder File Editor. Then I was able to cut it up and save the files quickly with no changes to the file format. It was rather quick.
 Thanks for the help folks!
  WVC1 in .wmv playback problem with MPC-HCBy andreyi in forum Newbie / General discussionsReplies: 6Last Post: 23rd Jan 2010, 12:35
  How to add streams to WVC1 (WMV HD)By ChileanGuy in forum Video ConversionReplies: 0Last Post: 21st Jan 2009, 12:16
  WMV (WVC1) to .TSBy teknix1 in forum Video ConversionReplies: 6Last Post: 30th Dec 2008, 16:42
  wvc1 codecBy pixel zombie in forum MacReplies: 2Last Post: 26th Nov 2007, 14:18
  Converting an ASF (WMV) fileBy yadda in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2007, 07:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
