Hi,
I have a video that I'm wanting to block the edge areas out. So if the video was split vertically down in 3 parts, I only want to have the middle part visible.
I heard that VirtualDub can do this but I'm not sure how its done.
Can someone point me in the direction of a guide that would do what I'm looking for please?
Thanks for any help that can be given.
Thanks for the quick reply.
The fill looks good.. but I'm having problems saving the filter to the actual video. And when I save the file its just totally black screen. Im going to have to mess around with this virtualdub some more.. only just downloaded it recently. -
Do you see your video in the input pane? After adding the fill filters do you see the correct result in the output pane?
No. Is the output pane the view that plays the videos? or are you meaning a different box?
I don't see where the filter as been added. After I select either fill or crop I press Done and it takes me back to the main video area. But it just seems to be the original unfiltered video that is playing still, unfiltered.
Blocking Artifacts in MPEG-4 AVC / H.264 Video
By Eva-Unit01 in forum Video ConversionReplies: 0Last Post: 28th Aug 2010, 15:36 -
Blocking artifacts in H.264 decoded video
By gabbasb in forum ProgrammingReplies: 0Last Post: 18th May 2010, 05:44 -
Stand-alone Recorder (video blocking signals)
By grom in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Dec 2009, 04:19 -
How to shifting an area of video frame in avisynth?
By djnice in forum Video ConversionReplies: 6Last Post: 31st Mar 2008, 01:24 -
Why is my converted video stretched beyond the viewing area on my TV?
By Clare in forum Video ConversionReplies: 2Last Post: 6th Oct 2007, 14:41
