Hi all
Got a really odd problem but not sure how to fix it. I've got some AVI files that I want to edit/trim within VirtualDub, a piece of software I've used many times before. The problem is, VirtualDub seems to have become really jerky and choppy and won't play any file at all without start-stop-start-stopping all the way through and it's making it nigh-on impossible to get anything done. I was using an older version of the software but just downloaded and tried the latest version yet it's exactly the same.
Any idea how to fix it?
cheers
Results 1 to 13 of 13
Yep, they play fine outside of VirtualDub.
Mediainfo dump:
Format : AVI
File size : 96.0 MiB
Duration : 4mn 18s
Overall bit rate : 3 116 Kbps
Writing library : VirtualDub build 32842/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 4mn 18s
Bit rate : 2 928 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 30.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy -
not sure, it's not a very "taxing" video, so it's unlikely to be a "cpu horsepower" issue
is there audio in the avi ? if so what kind ?
are the performance and display options set as default ? -
The audio format is Microsoft ADPCM 4 bit 177kps.
Do you mean the Performance option under Options with "AVI Output Buffering" and Wave input buffering"..? I set them both to 6mb and tried again and, the video actually lasted a little a longer before then starting to stutter again... -
I believe the official stance is that "VirtualDub is not a player," and that there's always a chance normal playback of a video loaded in VirtualDub might not display the way you want it to (so always test normal playback with a different player). Can't remember exactly where I read that, though, as it's been quite some time.
Checking the VD documentation on its homepage, I did find this, though:
Originally Posted by http://www.virtualdub.org/docs_processing.htmlIf cameras add ten pounds, why would people want to eat them? -
Ahar!
Have got the "Drop Frames When Behind" option ticked and it's all fine now!
Cheers...
Ah, scratch that last statement. It made it work ok for a bit but now, once again, it's stuttering and it's even worse than before....
What Ai Haibara said. Virtualdub is not meant to be a media player.
I'm not sure why you are having problems with an XviD AVI. I have trouble trying to move around in an MP4 file but not with AVI. A 2.66Ghz P4 might not have enough processor power to play them correctly in Virtualdub.
You might check in the Virtualdub forum to see if there is possibly a bug in the new version. I'm using version 1.10.0 with no issues.
http://forums.virtualdub.org/
Jerky playback
By hi2shy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Nov 2010, 17:44 -
Jerky Playback
By electrowiz in forum Video ConversionReplies: 1Last Post: 25th Aug 2010, 17:16 -
jerky playback
By VOYAGER2009 in forum Video ConversionReplies: 19Last Post: 22nd Feb 2010, 06:27 -
Jerky video playback
By realmfighter in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 12th Nov 2009, 02:41 -
Jerky playback on TV from PC using TV Out
By digidude in forum Software PlayingReplies: 0Last Post: 30th Dec 2008, 18:26
