  1. i have tried everysingle program on this site and cant find one to work, PLEAS HELP ME
    http://video.citytv.com/video/detail/96521212001.000000/season-3-ep-15-indonesia-a-hom...ay-departures/
    i think this part of the code is interesting;
    <script language="JavaScript" type="text/javascript" src="http://admin.brightcove.com/js/BrightcoveExperiences.js"></script>
    <script src="http://admin.brightcove.com/js/APIModules_all.js"> </script>
    <object id="myExperience45047864001" class="BrightcoveExperience">
      <param name="bgcolor" value="#000000" />
      <param name="width" value="640" />
      <param name="height" value="360" />
      <param name="playerID" value="64541073001" />
      <param name="publisherID" value="1632712407"/>
      <param name="isSlim" value="true" />
      <param name="wmode" value="opaque" />
    	  <param name="adServerURL" value="http://ad.doubleclick.net/pfadx/rogers.citytv/Video/Player/citydepartures" />
      		<param name="additionalAdTargetingParams" value=";mediatype=episode;season=3;show=;episode=15;genre=Reality" />
      <param name="@videoPlayer" value="96521212001" />
      <param name="optimizedContentLoad" value="true" />
      <param name="videoSmoothing" value="true"/>
     </object>
    i think it has do do with something called brightcove, then plays the ad at rogers, then runs that video with the "value="96521212001""
    do you guys think this will save in cache
  2. Member bat999's Avatar
    Feb 2008
    That video won't play in UK.
    So for me it really is the HARDEST STREAM CAPTURE EVER
  3. I can't watch it either but found rtmpe urls. StreamTransport, CooJah or RTMPDump should work.
    rtmpdump -r rtmpe://cp80642.edgefcs.net/ondemand/citytv/1632712407/1632712407_96531336001_Departures-315-copy.mp4 -W http://admin.brightcove.com/viewer/us1.25.01.00.2011-02-22130058/connection/ExternalConnection_2.swf -o 1632712407_96531336001_Departures-315.flv
  4. Member bat999's Avatar
    Feb 2008
    @ k.
    Yes, RTMPDump has downloaded that show OK here using your command.
    I tried rtmpsrv and rtmpsuck and StreamTransport and URLsnooper2 but none of them could find a link because the video wouldn't play.
    How did you go about finding that RTMPDump command if it wouldn't play for you either?
  5. I searched the Temporary Internet Files folder and found the file "amf?playerId=64541073001" that contained the rtmpe links. I took the swf player information from a short video on citytv.com that I could watch.
  6. thanks guys, ill try and decipher this, thanks alot
  7. ok stream transport works, but kinda slow download, oh wel, thanks alot guys, if you could show me how you did RTMPDump i would apreciate it, but thanks alot
  8. what cms are they using?
