Results 1 to 9 of 9
  1. I have a video that is supposed to be 1080p. Should that be reflected in the "Height" measurement in mediainfo?
    Or does it affect other measurements?
    Here are the specs:
    Format : Matroska
    File size : 4.65 GiB
    Duration : 2h 20mn
    Overall bit rate : 4 750 Kbps
    Movie name : KK BluRay 1080p AC3
    Encoded date : UTC 2011-01-13 20:19:36
    Writing application : mkvmerge v4.3.0 ('Escape from the Island') gemaakt op Sep 5 2010 10:30:51
    Writing library : libebml v1.0.0 + libmatroska v1.0.0
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2h 20mn
    Bit rate mode : Variable
    Bit rate : 4 096 Kbps
    Maximum bit rate : 25.0 Mbps
    Width : 1 920 pixels
    Height : 800 pixels
    Display aspect ratio : 2.40:1
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.111
    Stream size : 3.93 GiB (85%)
    Writing library : x264 core 105 r1732 2b04482
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=9 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=4096 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / ip_ratio=1.40 / aq=1:1.00 / nal_hrd=vbr
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Duration : 2h 20mn
    Bit rate mode : Constant
    Bit rate : 640 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 641 MiB (13%)
    Language : English
    Text #1
    Format : VobSub
    Muxing mode : zlib
    Codec ID : S_VOBSUB
    Codec ID/Info : The same subtitle format used on DVDs
    Language : English
    Text #2
    Format : VobSub
    Muxing mode : zlib
    Codec ID : S_VOBSUB
    Language : English
    Text #3
    Format : VobSub
    Muxing mode : zlib
    Codec ID : S_VOBSUB
    Language : English
    Text #4
    Format : VobSub
    Muxing mode : zlib
    Codec ID : S_VOBSUB
    Language : French
    Text #5
    Format : VobSub
    Muxing mode : zlib
    Codec ID : S_VOBSUB
    Language : French
    Text #6
    Format : VobSub
    Muxing mode : zlib
    Codec ID : S_VOBSUB
    Language : Hindi
    Text #7
    Format : VobSub
    Muxing mode : zlib
    Codec ID : S_VOBSUB
    Language : Hindi
    Text #8
    Format : VobSub
    Muxing mode : zlib
    Codec ID : S_VOBSUB
    Language : Arabic
    Text #9
    Format : VobSub
    Muxing mode : zlib
    Codec ID : S_VOBSUB
    Language : Dutch
    Menu
    00:00:00.000 : en:00:00:00.000
    00:10:26.251 : en:00:10:26.251
    00:15:06.322 : en:00:15:06.322
    00:24:27.216 : en:00:24:27.216
    00:39:49.304 : en:00:39:49.304
    00:49:52.406 : en:00:49:52.406
    00:54:55.000 : en:00:54:55.000
    01:04:37.624 : en:01:04:37.624
    01:09:47.058 : en:01:09:47.058
    01:20:24.570 : en:01:20:24.570
    01:30:43.480 : en:01:30:43.480
    01:41:44.098 : en:01:41:44.098
    01:46:57.661 : en:01:46:57.661
    01:50:24.576 : en:01:50:24.576
    01:58:59.674 : en:01:58:59.674
    02:03:57.180 : en:02:03:57.180
  2. Member zoobie's Avatar
    Feb 2005
    Florida
    also use gspot to verify although it may not do mkv but still good to have around
  3. Oh yes, that explains the 'p,' but could the resolution really be 1080? Or closer to 720?
    I'm not being a stickler on video quality as much as figuring out if I am reading it correctly.
    Thanks!!
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Height : 800 pixels
    This should mean the video is 1920x800 with a 2.40:1 aspect ratio. That is nonstandard. My guess is it was cropped and resized somehow.
    If it really was 1080 it should read width 1920 height 1080.
  5. OK, so I'm not crazy! thanks again!
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    Well I'm not a medical doctor so I can't make that diagnosis
    But for another opinion on the video issue yes I would say you're not crazy about that - other members are free to debate however.
  7. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    1920x1080p version would include letterbox bars for 2.40 to 1 aspect ratio.
    http://www.kiva.org/about
  8. Someone started with a 1080p 2.4:1 aspect ratio Blu-ray rip (1920x1080) and cropped away the black borders leaving an 1920x800 frame. So it still has all the picture information of the original 1920x1080 frame -- except for recompression losses. For all practical purposes it is still a 1080p video, though maybe over compressed.
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    At an average bitrate of 4 096 Kbps that is a pretty fair assumption (and probably being generous)
    Read my blog here.
