Results 1 to 13 of 13
    Feb 2011
    n ireland
    hi folks, first time poster and not really clued up on all this stuff.
    anyway i have numerous films on my hard drive which have been ripped using Magic DVD Ripper and what i would like to do now is copy them back on to blank DVDs.
    if i need to download something where is the best and safest place to get it.
    any help appreciated
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Even though Magic DVD Ripper is a piece of garbage...we'll try to ignore that for now. A "rip" of a DVD is an exact copy of a DVD that will contain a VIDEO_TS folder.....is that what you have?.....and what size is the VIDEO_TS folder.
    Feb 2011
    n ireland
    they are all AVI files and between 06-1gb
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Some DVD players can play (some) AVI files.
    Copy some onto a DVD, as a data disc, and see what happens.
    Use a DVDRW if you have one to experiment.
    Use ImgBurn.
    Feb 2011
    n ireland
    Use ImgBurn.
    thanks for that i have downloaded that, but i am probably being stupid but cant find how to add film to add to it.
    on image burn---- on the source part i browse file and when i select films and open that it then gives me a list of the films in there but whenwever i open one of them up then there is nothing there to download?
  6. Member yoda313's Avatar
    Jun 2004
    The Animus
    You can drag and drop a whole folder in imgburn. It will ask you if you want it to be the root directory. If you want multiple folders you can do that too as long as it will fit on your disc.
    Also if these aren't divx or xvid avis and your dvd player CAN'T play them you will need to convert them to an actual dvd or dvds depending on how many and how large the files are.
    There are many many programs that can make dvds from avi divx files (assuming they are divx or xvid - you can use a program like gspot or mediainfo to find out exactly codec was used to make the avi files - the codec is the actual video type that the video uses to play in the compressed form).
    Examples of programs to use to convert to dvd include format factory, super, avstodvd, and mulitavchd. Some are simpler than others but this list all includes a lot of customization options. Please note the faster you computer is the faster the conversion time will be naturally.
  7. Instead of clicking in folders once you get to the avi press select files.
    Heres a very brief tutorial...
    Edit: 2nd Image is wrong once you go open folder and search for it you select it then press select folder button and for AVI's press the open files then when you get to it or them select them and press select files button.
    Also you can drag 'n' drop the avi's or folder onto imgburn and just press burn.
    Feb 2011
    n ireland
    ok i cant get this to work, were do i drag the folder too.
    1 i open up imgburn and select Write image file to disc ?
    2 i click on the folder beside Please select a file...
    3 select desktop then films then i have list of films in this folder, but where do i drag it to?
    Feb 2011
    n ireland
    cheers i will have a go at that
    Feb 2011
    n ireland
    somethings is happening now folks so hopefully that is me up and running, thanks alot.
    out of interest why do you say magic dvd ripper is no use? what would i use that is better/quicker as it does take about 2 hours to rip a childs dvd.
  11. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Then just re-rip your original DVDs. Those files you have are highly compressed crap and will never look as good as your originals ever again.
    Feb 2011
    n ireland
    ok so i would just be better copying the dvd to another dvd theough imgburn?
  13. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Since you've already got that Magic software.....just set it to give you a real DVD and not some compressed file.
