I am converting a BluRay to MKV - 1:1 conversion in terms of size. The movie is 23.976 fps.
But after running MKVmerge, there mkv file has no FPS and cant play.
Using TSmuxer to demux .264 video stream
Then running the .264 file through MKVmerge. MKVmerge tells me it cannot determine the FPS.
I go to format specific options and choose 24000/1001
BUT the resulting MKV has no FPS and cannot play. Why?
Results 1 to 1 of 1
How to convert a BluRay disc into a .MKV 720P file
By ioannis66 in forum User guidesReplies: 26Last Post: 22nd Oct 2013, 13:45 -
Witch the best way to convert a BluRay Movie to MKV ( size DVD9 or else)
By siopilos in forum Blu-ray RippingReplies: 9Last Post: 12th Feb 2012, 21:59 -
If MultiAVCHD is not supported, what is good tool to convert MKV to Bluray?
By Yanta in forum Newbie / General discussionsReplies: 7Last Post: 16th Sep 2011, 02:38 -
mkv output file audio bitrate is much higher than what I set it to convert
By Shadotaku in forum Video ConversionReplies: 0Last Post: 12th Sep 2011, 14:55 -
Using tsmuxer to convert mkv to bluray and the aspect is squished.
By heckybaby in forum Authoring (Blu-ray)Replies: 8Last Post: 9th Jun 2010, 09:07
