  1. Member stackner's Avatar
    Mar 2004
    Digital World, Australia
    i have windows 7. just installed sp1. now all my videos play in media player. even if i right click a file and choose a new programe and tick always use this program the next time i open the file its back to media player. i can not find a way to stop windows media player being the default now.
  2. Member darkknight145's Avatar
    Feb 2007
    Australia
    What player do you want to be the default?
    You should be able to set this up in the player you want to use, look for associations or extensions
  3. Member stackner's Avatar
    Mar 2004
    media player classic.
    tried everything. but since installing win7 sp1 it just keeps defaulting back to windows media player
  4. Mod Neophyte redwudz's Avatar
    USA
    MPC-HC did the same on my W7 computers. Apparently it's not easily included in the context menus. (Shows up when you R click a file.) I finally got it to stay there, but don't remember how. Maybe just re-installing it.
  5. Start MPCHC as Administrator, select View -> Options -> Player -> Formats, select all file types you want it to play.
  6. Member stackner's Avatar
    Mar 2004
    does not work for me with plain old MPC not MPCHC . it was fine until i installed win7 sp1. i would right click choose mpc as default and from then on double clicking a file would open it in mpc but now its always windows media player crap.
  7. Member stackner's Avatar
    Mar 2004
    ok its working for MPCHC version so ill use it. cheers.
