I am a voice instructor and run my mics into a Tascam audio interface which then goes into my Yamaha Stagepas 300 and into my computer for audio recording. I'm trying to use the mic input on my Canon Vixia HFM30 and get the sound from my sound system to go to my camcorder. I've done this successfully with my old non-digital camcorder but am not able to get it to work with my new camcorder. Is there something that I need to change on the camcorder?
try going into your cam menu to the mic settings and see what's up
What format does your Yamaha Stagepas 300 export? If line or mic XLR 600 ohm you should look at the Beachtek DXA-2T.
http://www.beachtek.com/
http://www.google.com/products/catalog?hl=en&sugexp=ldymls&xhr=t&q=beachtek&cp=5&bav=o...d=0CDYQ8wIwAg#Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Ringing with External Mic
By LifeChronicles in forum Capturing and VCRReplies: 2Last Post: 25th Apr 2012, 17:18 -
Looking for a minidv with 1394, external mic...
By Haopengyou in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Apr 2011, 16:16 -
External mic
By ipaddle4fun in forum Newbie / General discussionsReplies: 1Last Post: 7th Mar 2011, 21:46 -
External mic recommendation
By helper in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 5th Aug 2010, 15:57 -
Need help buying a second hand camera with external mic
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 18th May 2009, 20:10
