out of curiousity, if I ripped a dvd with clonedvd2 and the compression stayed at 100%, i realise you dont need to re encode because the rip would fit onto a dvdr.. but what if you were to re encode that 100% rip through rebuilder.... would the original quality be improved or do nothing?
Rebuilder is an encoder and not a ripper. A ripper will avoid transcoding if no further compression is required. Rebuilder wasn't programmed with such niceties because it should only be used when encoding is required, and will therefore re-encode regardless. This will take time and reduce quality for no benefit. It would not improve the quality unless you took the time to create a custom avisynth script with specific restoration faculties configured.
Read my blog here.
How to rip Bluray encoded in VC-1 and DTS HD
By Victor D in forum Video ConversionReplies: 21Last Post: 1st Oct 2011, 12:44 -
Possible to rip DVD to MP4 without compression?
By kashiko in forum DVD RippingReplies: 1Last Post: 27th Mar 2011, 14:47 -
Convert VC-1 Encoded Blu-ray Rip .m2ts to .mp4 in 32-bit Windows 7
By luigi2000 in forum Blu-ray RippingReplies: 10Last Post: 21st Jan 2010, 15:50 -
Single Episode Rip with MINIMUM Re-re-re-re-compression - HELP!?!
By jdmba in forum DVD RippingReplies: 6Last Post: 8th Aug 2008, 09:45 -
Best software to rip 'movie only' from dvd without compression.
By lordhutt in forum ComputerReplies: 2Last Post: 3rd Sep 2007, 19:37
