Results 1 to 17 of 17
  1. Member blinky88's Avatar
    Mar 2004
    Australia
    Comments from members would be greatly appreciated. I'm an oldie and know nothing about Laptops, that said, I would like Windows XP 32 bit OS not 64 bit. What is the best screen LCD or LED???
    Cheers from downunder.
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Finding one with XP (and not Windows 7 - the latest operating system) is going to be tough. Not impossible...but tough.
  3. Microsoft store got very good deals almost every week.
    I helped my friend get this one last week for $449
    http://www.techbargains.com/news_displayItem.cfm/243309
    newegg is selling the Acer AMD Phenom II Triple-Core N830 for $399,I read somewhere the battery doesn't last too long
    http://www.techbargains.com/news_displayItem.cfm/243967
  4. Originally Posted by blinky88 View Post
    Comments from members would be greatly appreciated. I'm an oldie and no nothing about Laptops, that said, I would like Windows XP 32 bit OS not 64 bit. What is the best screen LCD or LED???
    What you are calling LED is still a LCD Screen with a LED backlight instead of a LCD with a CCFL backlight.
    The advantage of the LED screen is less power used by the lighting. In theory this will allow longer battery life or else a smaller lighter battery, that's up to the designer.
    You should use Windows 7. Many of the new laptops won't work properly with XP assuming you can find the drivers for all the hardware.
    If I'd known I was going to live this long, I'd have taken better care of myself.
  5. Member blinky88's Avatar
    Mar 2004
    Australia
    Many thanks to the members who responded.
    Windows 7, Blue-ray, 64 Bit OS seems to be standard with new laptops so I decided to have a look on eBay.
    Has to be my lucky day .... I bought a really nice Laptop. A HP Compaq Pavilion dv5 1232TX, 4gb \ 400gb \ Vista. It is only 12-18 months old and has a remaining 12 months warranty Feb 2012, looks new, unmarked, $600 plus postage. I have no idea what the retail price was when they were available ..but.. it ticks all the boxes for me ..ie.. except Vista, I prefer XP\2.
    Thanks again everyone, thank you, appreciated.
  6. Member blinky88's Avatar
    Mar 2004
    Australia
    Hi All, it appears it can prove difficult to downgrade from Vista to XP\2 because of a driver issue, have to handle that problem when I receive it. I would really appreciate if a member can throw some advise my way.
    Nov 2005
    theres a forum out there, laptop oriented, that gives the driver details of most common laptops so u can download them and use them when u install xp. I've used it a few times a few years ago to downgrade from vista to xp...it worked fine
    cant remember the name of the forum though
  8. Originally Posted by blinky88 View Post
    Any particular reason for not wanting 64-bit? Just about any laptop in the $600 range these days is going to come standard with 64-bit Win 7, so 64-bit is becoming more and more mainstream.
    -drjtech
    They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
    --Benjamin Franklin
  9. Member blinky88's Avatar
    Mar 2004
    Australia
    I have been using XP\2 for many years and have never had a problem of any description and from the comments I've read about Vista, I'll stick with the devil I know.
  10. Member blinky88's Avatar
    Mar 2004
    Australia
    Moontrash, really be helpful if you could remember the name.
  11. Originally Posted by blinky88 View Post
    Two things to consider:
    1. Windows 7 is definitely not Vista.
    2. Modern laptops are not designed to support XP. If you intend to run XP make certain the drivers you need are actually available before you make your purchase.
    -drjtech
    --Benjamin Franklin
  12. Member blinky88's Avatar
    Mar 2004
    Australia
    Hi drjtech,
    The laptop I bought is not new perhaps 18 months old.
    I have only heard good things about Windows 7 and I am giving that a lot of thought.
    Thanks for your comment, appreciated.
  13. Member hydra3333's Avatar
    Oct 2009
    Australia
    . snip due to insulting post below. Speaking of feeble, "your" should have been "you're".
  14. Member blinky88's Avatar
    Mar 2004
    Australia
    Every village has one, too bad you're an Aussie.
  15. Member hydra3333's Avatar
    Oct 2009
    Australia
    that's funny, given what you bought and your questions.
  16. Member blinky88's Avatar
    Mar 2004
    Australia
    I thought it was appropriate for the comment you made BEFORE your edit.
  17. Member blinky88's Avatar
    Mar 2004
    Australia
    Thank you to all members who have taken time out to respond, appreciated.
    Conclusion: I finished up buying a HP dv5 1232TX which had Vista installed. I found Vista to be a monster and have downgraded to XP\3. The laptop really is a nice piece of gear and is running like a dream, no problems whatsoever.
