I am a noob about Bluray. Just paly some Bluray few days ago.
I have some questions about bakup Bluray. Can you answer me?
- I see somebody backup their Bluray movie in HDD computer, they call "BD Re-encode". They shrink one Bluray disc (about 40-50 GB) into 25GB, and enven 9GB (they call: BD 9). So, will this backup method keep orginal quality of movie? I doubt that, because the size is too small (9GB) to orginal BD disc. If the quality cant be keep, why don't call "Encode" or "Rip" ?
- The other method backup is: "Remux". With this method, they can choose to keep disc menu or not, and remove some unnecessary stuff like some audio streams. And the size of movie after remux isn't too small to orginal disc. They said Remux will keep orginal quality. I think so. But i dont understand: the orginal movie has AVC, or VC-1 video codec. The movie after remux often has H264 video codec. Why ?
I don't intend to backup my Bluray disc in computer, just want to resolve my doubts. Please help me. Thanks![]()
BDrebuilder can shrink a BR disk to BD25 or BD9 in either full disk or movie only mode. A movie only to BD9 looks very,very good,BD25 better. A program like TSmuxer can remux movie only allowing you to select what streams to keep,it does not re-encode the video,avc would remain avc.
1. You might be able to fit the main movie into 25GB. But 9GB would require reencoding/encode/reconverting/reconversion = losing quality.
2. If you change codec it also requires reencoding. -
h264 has an excellent compression ratio for high def source material. It has more and more acceptance in playback devices like a ps3 or a wdtv media player - or a bluray player when authored as an avchd.Originally Posted by mocqueanh
The original codecs used in bluray are very large and in order to compress to a dvd dual layer for "bd9" discs you need to reencode it - change the quality. They can look very good but won't be the same as the original version.
Bluray backed up to bluray media will be much closer to its original form - compressing to bd25 from bd50 should keep it close to its original form with minimal reduction in quality while maintning features.
Think of converting to h264 from bluray the way you would have converted dvd to divx in years past. The quality can be good but won't be exactly the same as the original. And think of going from bd50 to bd25 the same as shrinking a dvd from dvd9 to dvd5 - transcoding a dual layer to single layer.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Well, they told me that remux is cut unecessary stuff (like Spanish audio in English movie, or commentary audio), so the quality is intact. And i see their BD remux is 30GB (the orginal BD disc is 36GB), isn't too small to orginal. I just confused their Remux video codec is H264.Think of converting to h264 from bluray the way you would have converted dvd to divx in years past. The quality can be good but won't be exactly the same as the original. And think of going from bd50 to bd25 the same as shrinking a dvd from dvd9 to dvd5 - transcoding a dual layer to single layer.
How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?
By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 13:39 -
True PAL 1080i 25fps Bluray -> native 1080p 24fps Bluray?
By BilboFett in forum Blu-ray RippingReplies: 1Last Post: 27th Feb 2011, 11:29 -
bluray iso back to bluray format
By mysts in forum Blu-ray RippingReplies: 3Last Post: 4th Jan 2011, 14:42 -
How to re-author back to bluray from BDMV bluray structure?
By eummagic in forum Authoring (Blu-ray)Replies: 1Last Post: 1st Dec 2010, 21:14 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 14:05
