I have a 2 hour footage (presentation, no action or too much camera movement) that I just edited in Premiere CS5 and now I'm about to make my first DVD.
Should I export my edited work in Premiere via the File -> Export -> Media menu to make it DVD ready or does Encore handle that?
I persume I should encode the footage with the MPEG2-DVD preset which makes my file output *.m2v? The project is meant to be basic DVD 720x576 footage.
I was experimenting in Encore and I noticed the Transcode option, whats it for?
Also, after trying to export the 2 hour footage (with some overlay titles and graphics) in MPEG2-DVD preset, Premiere estimated 20 hours to complete the task. Is this too much? I work on iMac Core 2 Duo 2.8
File --> Export Media. This will open up the Adobe Media Encoder using which you can encode to MPEG-2 DVD. It will produce .m2v and .ac3 (if Dolby Digital is selected as audio). These .m2v and .ac3 files can then be imported into Adobe Encore for authoring purposes. Authoring involves creaing menus...etc, and NOT the actual encoding. It is best to leave the encoding tasks to an encoder such as Adobe Media Encoder (which uses MainConcept engine). Since your video is over 2 hours long, you might want to set the bit rate properly so that the final output fits on a singl layer disc (if that is your media of choice). If you are going to use Dual Layer DVD Blank disc, then it will surely fit 2hours of video at maximum bit rate for DVD-Video.Should I export my edited work in Premiere via the File -> Export -> Media menu to make it DVD ready or does Encore handle that?
Read above.I persume I should encode the footage with the MPEG2-DVD preset which makes my file output *.m2v? The project is meant to be basic DVD 720x576 footage.
Encoding is the process of converting your 'source' material into a target format (such as MPEG-2 DVD), whereas transcoding is converting 'an already converted' video file into another format. Basically, encoding-the-encoded, if my understanding is right. From your Premiere, you will be 'encoding'. Encore will 'transcode' if (it thinks that) the encoded files that you supply to it are not entirely compatible with the final DVD Specification.I was experimenting in Encore and I noticed the Transcode option, whats it for?
I faced this issue long ago when I tried to export the video directly to DVD Disc from Premiere. I suggest you use the option Export --> Media, which will open-up Adobe Media Encoder. This should not take 20 hours.Also, after trying to export the 2 hour footage (with some overlay titles and graphics) in MPEG2-DVD preset, Premiere estimated 20 hours to complete the task. Is this too much? I work on iMac Core 2 Duo 2.8
Also, learn about CBR and VBR (for encoding) and bit rate calculations by browsing through the forum. -
Thanks for the reply! I will look into the forums for variable bit rates, also I have 5 hour material at disposal so I think I'll rather spread it across 4 DVDs, since I have some 4-pack boxes laying around
I think I've figured why Premiere estimated 20 hours for 1,5 hour DVD video.
I had the Maximum Render Quality option on. When I turn that option off, it dramatically speeds up the process. I hope it doesn't effect the final quality of the footage.
Encore CS5 Poor Quality DVD Burns
By chazStaples in forum Authoring (DVD)Replies: 3Last Post: 6th Dec 2011, 09:18 -
DVD quality from Encore CS5.1
By surffx in forum Authoring (DVD)Replies: 6Last Post: 21st Nov 2011, 05:51 -
encore dvd adobe cs5
By donnaglait in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2011, 07:30 -
Encore CS5 Loss in Rendered DVD chroma/saturation
By CKyle in forum Authoring (DVD)Replies: 0Last Post: 17th Jun 2010, 18:00 -
encode/transcode: Why use Encore rather than Premiere Pro?
By vid83 in forum Authoring (DVD)Replies: 2Last Post: 11th Jul 2008, 19:31
