Hi again,
I have an AVI that's not only PAL, but also looks beyond terrible. I'd like to know if there's a way (preferably using AviSynth) to convert the video to NTSC, but in doing so sacrificing as little of the video's integrity as possible.
Which method(s) would be the best/most recommended? I'm not sure what to put in to my script.
I doubt it's really of any use, but in case anyone cares, here's the MediaInfo data:
-Code:General Complete name : C:\FILE.avi Format : AVI Format/Info : Audio Video Interleave File size : 688 MiB Duration : 1h 22mn Overall bit rate : 1 159 Kbps Writing application : MEncoder Sherpya-SVN-r26446-4.2.3 Writing library : MPlayer Video ID : 0 Format : MPEG-4 Visual Format profile : Simple@L3 Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 1h 22mn Bit rate : 1 024 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 5:4 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.099 Stream size : 608 MiB (88%) Writing library : XviD 1.1.2 (UTC 2006-11-01) Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Codec ID : 55 Codec ID/Hint : MP3 Duration : 1h 22mn Bit rate mode : Variable Bit rate : 122 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Stream size : 72.5 MiB (11%) Alignment : Aligned on interleaves Interleave, duration : 26 ms (0.65 video frame) Interleave, preload duration : 515 ms
Results 1 to 13 of 13
If you don't like the PAL why do you want to convert and lower quality more?
http://www.kiva.org/about -
I was thinking the same thing, but then i thought maybe i misread it (or he miswrote)
If it looks terrible as the original PAL AVI (sic) then what makes you think it will look better converting it to NTSC ? -
I'd leave it at 25 fps and add pulldown flags with DgPulldown (assuming you're making a DVD). Then you don't have to change the audio length.
Donadagohvi (Cherokee for "Until we meet again")
Well if I may disagree, the pulldown hack is a good way to convert a MPEG2 file as it avoids reencoding.
But when your source is AVI or MKV, etc, and you're running it through Avisynth to encode to MPEG2, AssumeFPS is the simplest. The only issue is the audio is resampled and the speed is changed by a few percent -- but if your audio wasn't 48000Hz AC3 in the first place (and this was 44100Hxz MP3) you have to resample regardless.
Anyway, quite likely the original source was 24 fps film, the 25 fps PAL was probably just speeded up, so going to 23.976fps is getting closer to the original if that's a consideration. I find it imperceptible myself. -
I guess I missed the part where he said he preferred the avisynth way. After seeing that I guess what what Alan suggested would be appropriate.
Honestly I don't even mess with this stuff anymore anyway. I just play my vids through a networked media player. No conversion necessary.Donadagohvi (Cherokee for "Until we meet again") -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
