is it possible, is there a device that will convert a tv signal to a computer signal. (it would be preferable via vga conections)
i would like to use a computer monitor with a karaoke machine, which has a vga, but must go to a tv for video.
again, i would like my karaoke machine to display upon a computer monitor.
thank you
There are many scan converter that can convert composite or s-video to VGA for a computer monitor. For example:
http://www.amazon.com/gp/product/B000XY6N5Y/
http://www.amazon.com/VideoSecu-Composite-Adapter-Converter-1L9/dp/B001SJDESC/
http://www.amazon.com/StarTech-COMP2VGA-Console-Monitor-Converter/dp/B00006B8EI/ -
And what is the best way to record that video to AVI or MP4 format on your PC?
You need a capture card then and that has basicly nothing to do with this thread.
The scan converter is not going to improve the picture quality. In fact, it will probably be significantly worse with cheap scan converters. So there is no point in recording the VGA output of the converter. Record directly from the composite output of the karaoke machine. Any analog video capture device with a composite input will work.
https://www.videohelp.com/capturecards
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:16 -
Computer Guys Braggin' Time: What have you built that AIN'T a computer?
By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 15:19 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 12:06 -
Capturing Halo 3 gameplay from computer monitor to computer
By Jamo in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 00:06
