    Oct 2005
    Sourthern England
    Hi There
    I've been using svcd2dvd for a long while now and it's all been well until just today when encoding multiple .avi files with a menu and it fails when it gets to encoding the menu.
    The error log generated:-
    Version: SVCD2DVD 2.5
    Build: 2.5.5030.0
    Type: System.InvalidOperationException
    Source: System
    Message: Cannot process request because the process (3196) has exited.
    InnerException:
    StackTrace: at System.Diagnostics.Process.GetProcessHandle(Int32 access, Boolean throwIfExited)
    at System.Diagnostics.Process.set_PriorityClass(Proce ssPriorityClass value)
    at x3284ccece41ee22b.xc5b4b7804027a156.x160a0bf4de8f6 bd0(String xd168ac2ed64c4662, String xa6a477a49a1a2599, String x450f47a9028f884b, xa0efedb9fec1e88f x8b49c96cd0348808, Boolean x74effd3a0f44569e)
    at x3284ccece41ee22b.xddb8d1ea6c9958c7.x8291881ef07bb 5c7(Boolean x7ce1fdb24a74c398)
    at x3284ccece41ee22b.xd3764d4f1e921081.x4f3432523597d cf6(Boolean x7ce1fdb24a74c398)
    at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
    at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
    at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
    at System.Threading.ThreadHelper.ThreadStart()
    I had this the first time I tried encoding these .avi's and the error mentioned something about the menu background, so this time I used a different background pic other than the default one and the error message is above.
    Any help would greatly be appreciated.
    Best Regards
    GSMB
  2. Can you attach the log file for this peoject?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Oct 2005
    Sourthern England
    This is going to sound stupid, but where is the 'log file' stored, I still have the log files from an older version (v2) in it's folder but for this this version (v2.5) I can't see the log file.
    Sorry to ask a silly question as all your trying to do is help me.
    Best Regards
    GSMB
    Oct 2005
    Sourthern England
    I've just run the same project again to try and see a log file and it's completed the conversion and burnt the dvd.
    I'm a little embarrassed as just as I started the project I checked the hdd and noticed that there wasn't much space on the drive left, so I deleted some files and it now works, so my apologies for a raising an issue that was all my fault.
    I would still like to know where the log files are stored though
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Logs are found via Help->Open Logs
    Oct 2005
    Sourthern England
    Thank you very much.
    You know what I thought I looked everywhere lol
