I need some clarifications on this odd format . I have a tape i believe was recorded in s-vhs on a simple vhs (aka s-vhs et) . When i insert it i have the logo s-vhs which quickly appear then fade away.
The tape is played rather good except for two things:
1- The tbc don't like it: flagging at the top thus i have to disable it.
2- the scan lines are not displayed correctly at times (it seems my software have a hard time to blend them together smoothly for preview)
My vcr is a jvc 8600 so it's high end but not "ET" capable (record), i wonder if an Et capable would cure the problem.
What do you think ?
				Results 1 to 15 of 15
	Last edited by themaster1; 21st Feb 2011 at 20:56. *** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
	I used to know this, arrgh  . .
 SVHS-ET was a bastard child of SVHS that would record a form of SVHS to premium VHS tapes. I forget the details but Wiki would know. The main downfall of SVHS was expensive tape media. During the 80's VHS tape stock improved to the point they could record SVHS FM deviations at some loss of S/N to premium VHS tapes.
 I think playback requires an SVHS-ET deck. A standard SVHS deck would try to decode this as VHS with different FM deviation.
 I recall some trick where people drilled holes to fool the player into thinking this was SVHS media.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Extra holes hmm that's interesting. So that means if i happen to swap the case with a regular s-vhs case it would be interpreted as... s-vhs by the vcr *** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
	Well i've just tried the swaping thing, guess what the render is more stable now. I still have lines shifts but otherwise the decoding is more stable.
 Of course the TBC still don't like it (the flagging effect is now twicer big!) and i have disabled all other digipure options (b.e.s.t, digital 3R)*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
	Can someone confirm if he has known VHS ET tapes that they are playable on a regular s-vhs deck with the lilttle manipulation mentioned above, thank you.Please provide the tape standard (Pal/ntsc) and model of vcr. *** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
	don't confuse the ET and SVHS, they are two different functions.
 basically speaking, the ET function lets the vcr record svhs resolution / properties to the stanard vhs tape. but you won't get the actual level of quality you would get if you use an actual real svhs tape since the standard tape doesn't have the capability--tape grade ect. Also, you have to have a vcr that supports the -ET function. if my memory serves me, when i popped in the "faked" svhs recorded to standard vhs tape into a non-svhs vcr it was noisy or hard to see a picture. if your svhs does not have the -ET function then chances are you wont get satisfying results then if you played in an -ET vcr.
 anyhow, i did this test a couple of years ago to see for myself. i was mainly curious to see if the quality would be as good as svhs or at least trick my vcr into thinking it was identifying the tape as an ET recorded SVHS. basically, i was just tricking my vcr into thinking it had an svhs tape. my guess is, that the vcr was not totally fooled, and bumped down to the ET function and recorded in SVHS-ET mode.
 1. first, i needed to review an actual svhs and identify the hole placements, since i had plenty that was no probelm
 2. then i took a standard vhs tape and drilled the hole in the same placement as the svhs tape
 3. then i popped it into my svhs vcr, and then it the svhs light came on. it had tricked the vcr into thinking it had an svhs tape.
 the final conclusion was.. the vcr believed it had an svhs tape and i was able to record svhs-et resolution on the standard vhs tape. i did not get the same level of quality (sharpeness and no noise) like i would if actual a svhs.
 -vhelp 5484
	This seems to be JVC's standard warning.
 http://support.jvc.com/consumer/products/glossary.jsp?gId=34
 If you Google SVHS ET you get comments like this
 http://www.hometheaterhifi.com/volume_9_3/jvc-hrs-6855-ek-svhs-et-vcr-7-2002.htmlRecommends: Kiva.org - Loans that change lives.
	That review was written by an idiot.
 This is not even remotely related:
 "ET" mode (ignore S-VHS hole on tape, record S-VHS anyway)S-VHS ET recognizes that some tape really is good enough and will try its best after a short 'calibration' period when it starts recording.
 is unrelated to
 "calibration" -- a horrible feature that should never be used, neither for recording or playback.
 Just FYI.Want my help? Ask here! (not via PM!)
	No, it didn't.
 S-VHS is S-VHS.
 The format is separate from the actual tape.
 Whether it's on VHS tape or S-VHS tape, S-VHS signal is S-VHS signal, and any S-VHS player plays it.
 The "ET mode" was a mid-1990s JVC invention that saved us the time of drilling or melting holes in tapes.
 Not that you'd want to do this very often.
 It destroyed most tapes.
 Very few ever looked good this way.Want my help? Ask here! (not via PM!)
	There was a warning in the JVC VCR manual that advised not leaving a normal tape recorded in et mode
 on pause as it may damage the tape. Is the machine doing something mechanically different ? Faster head speed ?
 What else could "damage the tape" ?
	I've got a few SVHS decks and one SVHS ET deck. Long ago I tested this but won't try to repeat.
 Normal SVHS decks (pre-ET) determined SVHS by the cassette holes. If the holes matched, SVHS FM deviation was used. Lacking a hole, the tape was assumed to be VHS and VHS FM deviation was applied.
 SVHS ET used SVHS FM deviations on tapes with VHS cassettes. There must have been some kind of analysis used to discover SVHS video on VHS cassettes on both ET decks and later SVHS decks that supported ET tapes. Otherwise, the SVHS deck would assume VHS deviation frequencies.
 When I got a JVC SVHS ET deck, I tried playback in my NEC, Panasonic and SONY SVHS decks and they didn't use proper FM demodulation. That is when I decided not to use ET.Last edited by edDV; 24th Feb 2011 at 22:32. Recommends: Kiva.org - Loans that change lives.
	I'll have to keep a look out for that.
 I've not come across an S-VHS player made in the 1990s or 2000s that didn't understand S-VHS-ET.
 And from several brands, not just JVC.Want my help? Ask here! (not via PM!)
  vhs cassette not sitting down one side in vhs recorder ?By oldfellow in forum Newbie / General discussionsReplies: 3Last Post: 12th Mar 2012, 16:23
  Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52
  Best UK PAL VHS / D-VHS machines for digitising old VHS tapesBy pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21
  VHS Copy Protection when using a Dual DVD\VHS UnitBy wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25
  VHS To Harddrive Via S-VHS VCR & Matrox RT.X100By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
