Hi
Would be grateful for any help. Audio fine from start to finish when tape played through camera (Sony HVR-Z5). Captured using Premiere Pro. Audio fine in playback for roughly half the captured video then just disappears. Just don't understand it. Tried capturing 4 times. Same problem at exactly same point.
Just captured a test tape using same Premiere settings. Everything fine. Made over 40 videos using same settings on camera and in premiere. Never had a problem.
The only thing I did differently was to absentmindedly plug my headphones into the PC during capture. Would this have screwed the audio?
Thanks.
M
How were you capturing? Which format DV/HDV? DV has uncompressed PCM audio, HDV uses MPeg.
A Firewire capture never touches the PC audio system.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
clean the cam heads and try again. i've run into a bad spot or two on tapes that will kill the audio for no readily apparent reason. a couple i had to record up to the bad spot, then move past it and start capturing again. nothing would read there but the audio beyond the bad spot was fine.
Thanks edDV and aedipuss.
edDV - I have tried 6 times now. No joy.
aedipuss - I will go and try what you suggest and report back.
Thanks again both. -
I captured up to the frame where the audio drops out in playback. Perfect. Then captured after the dodgy point. Perfect. Thanks you so much aedipuss and edDV. Star.
Premiere Pro is exporting audio at -3dB
By Asterra in forum AudioReplies: 6Last Post: 11th Jul 2011, 19:38 -
Audio Problem with Premiere Pro
By solo_voyager in forum Newbie / General discussionsReplies: 4Last Post: 15th Jun 2011, 15:43 -
Premiere Pro WMV No Audio Problem - Help Please :)
By RalphPalph in forum EditingReplies: 6Last Post: 21st Aug 2010, 11:58 -
Premiere Pro audio/video sync
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 11th Nov 2007, 16:36 -
One channel of audio in Premiere Pro 1.5
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Oct 2007, 23:00
