Back in the NTSC days, many broadcast stations (mostly PBS, but occasionally others) would broadcast a time signal embedded in the non-display portion of the scan. The non-display portion could also carry other services too, like CLOSED CAPTIONS.
However, as far as I can tell, there is NO standard for an embedded time signal in an ATSC broadcast, even though they still transmit CLOSED CAPTIONS plus more content than NTSC was capable (ie, Program Guides).
In the "good ole days", you could set your TV and your VCR to automatically reset the clock daily, so things would start recording (in the case of the VCR) at the proper time. Now, we have to revert back to the times prior to the "good ole days" when you had to manually reset the recorder clock once or twice a month.
Does anyone know of any reason why a time signal is not being sent? It certainly isn't because of a "lack of bandwidth". I currently own a Toshiba DVR that I have to set manually and I have recently acquired a Magnavox MDR513 HD PVR that also needs to to have time manually set by hand.
I consider the lack of a time signal to be a huge step backwards.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Actually, there is a time code embedded in the ATSC signal. I have ATSC to NTSC converter boxes that maintain their clocks according to the time code they receive, although that time is often incorrect by at least a couple of minutes, or as much as 5 hours. There is no way to set their clocks manually.
I'm not sure what the story for time codes is with clear QAM.
If your recording devices are receiving signals from an antenna, they either aren't finding the new digital time code, or the time code they are getting is wrong.Last edited by usually_quiet; 21st Feb 2011 at 12:40.
PAL - what is its resolution in 16:9 broadcasts?
By snadge in forum DVB / IPTVReplies: 19Last Post: 22nd Oct 2013, 06:01 -
Advice on a Down Converter for 16:9 Broadcasts
By Plarocks in forum DVD & Blu-ray RecordersReplies: 14Last Post: 13th Jan 2011, 01:35 -
Time Domain Correction (TDC) and Black and White RS-170 video signal
By tpg in forum Capturing and VCRReplies: 0Last Post: 26th Nov 2010, 09:21 -
Capturing ESPN360 broadcasts
By DVWannaB in forum Video Streaming DownloadingReplies: 26Last Post: 2nd Oct 2009, 23:43 -
ATSC tuners in New Panis don't output true Hi-Def signal
By David K in forum DVD & Blu-ray RecordersReplies: 15Last Post: 30th Jan 2009, 22:05
