Results 121 to 131 of 131
Guys, thanks for all your help. I think I'll take it from here for now.
How do I open the Avisynth script command screen with Virtualdub?
And why is AvsPmod not recognizing any of the commands that it suggests after I type them?
ex: I type PixieDust(limit=5) and it will say "script error: there is no function named pixie dust". -
You mean to edit the script? You don't. VirtaulDub doesn't include a script editor. You have to use VirtualDubMod for that.
Probably because you haven't downloaded and installed the filters. -
I'm not jagabo but most third party filters and/or functions can be found either here:
http://avisynth.org/warpenterprises/
or here (including PixieDust):
http://avisynth.org/mediawiki/External_filters -
Only with VDubmod, type control-E. Not in the vanilla VDub.
Only the "core filters" are included in the Avisynth distribution. Many other functions and scripts are written and made available by users (and documented in AvsPmod) you have to download and usually copy the dll or AVSI into your plugins folder.
All of this explained in the documentation I pointed you to 120 posts ago. -
Well folks, I'm happy to announce that for the most part, all is set up and I've been testing Avisynth scripts and experimenting with my video. I even rendered a test script to HCEnc and created an mpeg (although it comes out with blocky artifacts on areas that were cleaned with hqnq3d and temporal smoother) but I'll keep toying with it. The point is that I'm finally a noob on his way to being one of the pros and I want to thank you all for your help. Alan, particularly you since your AvsPmod suggestion was the best thing there was for me. AND your advice on how to install external filters and make them work.
And you gave up on me (SHAME! lol). See? I got it.
So, thanks to EVERYONE who has posted on this thread for your help. I'll keep posting.
By the way, how do I load a Virtualdub plugin successfully into an avisynth script? I've tried with LoadVirtualdubPlugin("pathname") but nothing happened. Am I missing something? -
http://avisynth.org/mediawiki/Plugins
LoadVirtualDubPlugin ("filename", "filtername", preroll)
LoadVirtualDubPlugin ("filename", "filtername")
AviSource("filename.avi')
ConvertToRGB32() #virtualdub filters require RGB32
filtername() -
Ok jokers, this is the way I wrote the script working with AvsPMod and it does not recognize it:
LoadVirtualdubPlugin("vdub plugins","neatvideo")
MPEG2Source("C:\Users\mikey\Desktop\2dv files\killerwatt\killerwatt.d2v", cpu=6)
ConvertToRGB32(matrix="Rec601", interlaced=false)
Also, AvsPmod doesn't understand the term "preroll"
What am I doing wrong? -
You have to give the full path and name of the plugin you want to load:
LoadVirtualdubPlugin("C:\Program Files\VirtualDub\plugins\NeatVideo.vdf", "neatvideo")
neatvideo()
http://www.neatvideo.com/files/NVVDUG.pdf
You probably don't have to worry about the preroll argument. The Neat Video docs should mention it if you do.Last edited by jagabo; 12th Mar 2011 at 22:01.
Why are there 2 completely different 8mm formats??
By impmon2 in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2011, 00:03 -
How do I completely remove audio over a certain pitch?
By z-kun in forum AudioReplies: 3Last Post: 10th Mar 2010, 09:19 -
Video completely green and pink.
By corl45 in forum Capturing and VCRReplies: 2Last Post: 27th Jan 2010, 19:21 -
and now for Something Completely Different...
By ahhaa in forum Off topicReplies: 0Last Post: 28th Apr 2008, 09:20 -
Completely new
By orochimaru in forum Newbie / General discussionsReplies: 5Last Post: 26th Oct 2007, 17:32
