nevermind
Results 61 to 90 of 131
My problem is manifesting itself more and more....AVSPmod is also not recognizing Mpeg2Source. It is only opening files as DirectShowSource. I thought I deleted DirectShowSource, yet it is still in the sent to folder, which Windows doesn't allow you to tamper with.
How can I completely eliminate DirectSHowSource AND make it so that Mpeg2Source is recognized by VirtualdubMod and AVsPod??
Thanks guys. -
an .avs file is just a text file
you can open it up a .txt file in notepad for example and just type in whatever you want
Avspmod has registered filetypes in the options=>extension templates. You can configure it to open however you want.
It will open .avi files as AVISource() by default. It will open different files according to extension. If you right click and open the .d2v file with avspmod it will automatically fill in MPEG2Source() . Other filetypes might be set as DirectShowSource() . Or just type it in - it's not that difficult to type in 1 line
Vdubmod should open any valid .avs file. BUT - you have to create that valid avs file first
Post your exact script that vdubmod isn't opening. Did you follow the earlier instructions with the .dll ? -
Hi Poison
The trouble is that whether I type the script myself or right click it with AvPmod, save the script and try to open it with either Avs or Virtual, none of these programs are recognizing MPEG2Source at all. They're only recognizing DirectShowSource and I don't want to work from DirectShowSource. When I try to open Mpeg2Source scripts with AvPmod, I get a message stating "Script error: There is no function named "MPEG2Source".
When I try to open Mpeg2Source scripts with VirtualdubMod, it states that it does not recognize it.
Here's a sample of the automatic script that appears on AvsPmod when I right-click on my vob file:
MPEG2Source("C:\Users\mikey\Desktop\gbdgindex\kill erwatt\killerwatt.d2v", cpu=0)
Here's a sample of what I create myself in the text doc to open my vob file with virtualdub or AvsPmod
MPEG2Source("C:\Users\mikey\Desktop\movies\killerw att.avs")
How do I change it so that both programs recognize Mpeg2Source? -
pdr already requested that you post the exact script you're trying to open in VDub. If it's only that one line, go back to the sample script I gave you a couple of days ago and adapt it for this video. And go back and reread the three docs included in the DGMPGDec package.
Nothing will open that as you're trying to use MPEG2Source on an AVS rather than on a D2V project file created by DGIndex.Here's a sample of what I create myself in the text doc to open my vob file with virtualdub or AvsPmod
MPEG2Source("C:\Users\mikey\Desktop\movies\killerw att.avs") -
Ok, bottom line. How do I open a VOB file using MPEG2Source with VirtualdubMod or AvsPmod?
That's all I need to know. Are there settings I need to tweak on either of the two programs for them to recognize the file? -
I told you already 2 days ago. We're going backwards. Make your D2V project file using DGIndex and:
LoadPlugin("C:\Path\To\DGDecode.dll")
MPEG2Source("C:\Path\To\Video.d2v")
Adjust for your own names and paths. Stick those two lines inside an AVS. An AVS might be a TXT file renamed with the extension .avs, like Movie.avs. Open it in VDub. If there's an error message you can't figure out, give it to us as well as your complete script.Last edited by manono; 28th Feb 2011 at 00:55.
Ok, so as per Donald Graft's instructions on DGDEcode AND yours manono, I created an avs file listed as follows:
Loadplugin("C:\Users\mikey\Desktop\camillesfaves\h alloween\DGDecode.dll")
Mpeg2Source("C:\Users\mikey\Desktop\camillesfaves. d2v")
and this is what I get when I try to open it with VirtualdubMod:
Avisynth open failure:
LoadPlugin: unable to load
“C:\Users\mikey\Desktop\camillesfaves\halloween\DG Decode.dll”
(C:\Users\mikey\Desktop\camillesfaves\halloween\ha lloween.avs.avs,line1) -
Can't say I haven't been doing my homework guys; however this is really becoming a pain in the ass and frankly, if it weren't for the fact that I'm really into the videos I'm working on....I'd have given this up already.
Did just that. No there is no space. Here's the lovely surprise I get from VirtualdubMod:
Did that. Nothing. Why is Avisynth not making Virtualdub recognize MPEG DESPITE EVERYTHING I'M DOING?????
This is a very weird error. Are you sure there are no typos or spaces as you have indicated above? For example "halloween" has a space, but maybe that's the message board screwing things up
Maybe something got corrupted along the way?
Try redownloading and uninstall then reinstalling avisynth , and redownloading DGMPGDec package. Place fresh copy of DGDecode.dll into avisynth/plugins folder -
Is there any way I can put the MPEG2Source in my sent to folder then to make this happen?
TO make what happen? I would start over , from scratch
I looked at some of your posts and it mentioned you were deleting directshowsource or something like that? Are you randomly deleting .dll's and things from the plugins folder ? That could cause what you are seeing if you deleted some things you weren't supposed to.
I would seriously start all over. Re-install avisynth. Re-index the file. Make a new script . This should only take a few minutes -
I mentioned this before but I don't recall any response: are you running 64 bit windows?
https://forum.videohelp.com/threads/332117-completely-new-to-avisynth-please-help?p=205...=1#post2059375
You have to keep your 32 bit programs, DLLs, and codecs separate from your 64 bit programs, DLLs, and codecs. -
You know what's funny jagabo, I was just remembering you mentioned that. I have Windows Vista. How can I tell what bit windows I'm running?
I just re-downloaded Avisynth and although the icon is on my desktop, the folder that contains plugins is no longer there . When I go to start, and I type it I see it but it's no longer available.
I get a message stating that the shortcut no longer works properly or has been moved. I thought I could completely eliminate Avisynth from my computer from "programs and features" like I would any other software. At least I thought that's what I did.
This is getting really stressful. It's as if it's a game. This works, but that doesn't. Then when that works, then this doesn't. -
i have attached a file pathcopy. rar
extract the pathcopy.msi inside, and double click on it.
in windows explorer, right click on any file-it will give an option copy path to clipboard
extremely useful with avisynth, in avoiding errors with file names.
i always create my avs files either with virtualdubmod or dgindex, using a template, and edit them with virtualdubmod, unless i need to tweak some filter accurately, when i use avsp.
Why are there 2 completely different 8mm formats??
By impmon2 in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2011, 01:03 -
How do I completely remove audio over a certain pitch?
By z-kun in forum AudioReplies: 3Last Post: 10th Mar 2010, 10:19 -
Video completely green and pink.
By corl45 in forum Capturing and VCRReplies: 2Last Post: 27th Jan 2010, 20:21 -
and now for Something Completely Different...
By ahhaa in forum Off topicReplies: 0Last Post: 28th Apr 2008, 10:20 -
Completely new
By orochimaru in forum Newbie / General discussionsReplies: 5Last Post: 26th Oct 2007, 18:32
