Hi all. I hope to post the right place.I use VirtualDUbMod to capture my files and the problem is the Audio encoding. The natural source of video is MPEG2, but when I encode the video, i want to encode the audio.Below is a small video sample I made. The information I got from the Media Info.
Video
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 2mn 5s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 23.0 MiB (47%)
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
As you can see the audio encoding is so big. What should I do to succeed audio encoding to 128kbps?
Many thanks!
Streams -> Stream List
right click on stream -> Full Processing Mode
right click on stream -> Compression... select codec and configure, eg. LameACM, 128 kbps -
Many thanks for the info. Installed Lame3, and then restarted VirtualDubMod. The Lame3 appeared.
VirtualDubMod: Audio out of sync
By Ununhexium116 in forum EditingReplies: 4Last Post: 12th Dec 2011, 13:22 -
virtualdubmod no audio problem
By hell in forum Video ConversionReplies: 0Last Post: 4th Jan 2010, 16:49 -
VirtualDubMod - No audio decompressor
By MrFriendly in forum AudioReplies: 5Last Post: 3rd May 2009, 23:11 -
virtualdubmod audio problem
By aruwin in forum EditingReplies: 4Last Post: 18th Oct 2008, 01:08 -
VirtualDubMod - Does it keep audio sync?
By vodmare in forum Video ConversionReplies: 4Last Post: 13th May 2008, 01:15
I use
