Dear All,
Would you please confirm the procedure to convert .m2ts to .vob format i.e. bluray to dvd conversion. I tried DVDFab but it unable to do it properly after 4%..Please suggest ??
Thanks & regards,
Vikas
Results 1 to 9 of 9
form
vikas -
Thank you so much for your prompt response..I will try it and let you know if any problem observed ??
Thanksform
vikas -
Hi Boldrik,
I tried VSO Bluray to DVD but after conversion it's showing one error message frequently on screen during playback(This video was converted with Bluray to DVD trial version, Buy a unlock key to create video without this message).
Can we remove this error with trial version??
form
vikas -
Hi Boldrik,
Can we remove this error with trial version??form
vikas -
It sounds like its a nag screen. You'll have to buy the full version to remove it.Originally Posted by vikas.babu
Or go a different route. If you have the ripped m2ts files already on your harddrive you can use a program like avstodvd or multiavchd to create a standard dvd (with menus if you want). They don't make pop up screens afterwards they are the full unaltered image after you finish disc - unaltered in the sense you don't have any messages pop up - of course if its a high def image it will be downconverted to standard definition which is what you are doing when you make a dvd - resolution of 720x480 for ntsc or 720x576 for pal).Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Newbie Conversion questions: combine multiple .m2ts files
By Deku Scrub in forum Blu-ray RippingReplies: 10Last Post: 30th Aug 2013, 18:58 -
Best M2TS conversion options and what format to convert to?
By beltline in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 21st Mar 2010, 21:15 -
M2TS conversion and playback slower than Molasses in January
By HighVoltageMiner in forum Video ConversionReplies: 2Last Post: 13th Jan 2010, 15:45 -
M2TS to DVD/VOB
By eon_designs in forum Video ConversionReplies: 18Last Post: 8th Dec 2009, 07:45 -
Blu ray m2ts files not in order? mkv conversion
By davidc78au in forum DVD RippingReplies: 3Last Post: 11th Feb 2008, 11:39
