mkv2vob v2.4.9.
the last week I had several cases of mkv files that is around 5 GB and when I demux them it gets at least 1 GB smaller than the original (without transcoding!). When I later try to play them in my ps3 they wont start ...just black screen with no audio. And when I get info about the file it said 2 channel pcm?! should be 5.1. I never had this problem before and now its 5 times in one week!?! I also tried to install v.2.4.7 but it came out with the same result.I have checked the configuration 20 times and it should be ok; file split: fat32(4gb), vt auto, ofe auto, output type file,
please help!
	You could try make a m2ts or mp4 with https://www.videohelp.com/tools/sections/all-in-one-mkv-to-mp4-avchd-ts and see if it works better.
	thanks for reply. I tried once again and install 2.4.7....unplug internet cable to avoid upgrade and voila it works  have to wait for a better upgrade before i check "automatic update" have to wait for a better upgrade before i check "automatic update"
  Black screen, but Audio is fine - when playing after renderingBy DUCKVILLELOL in forum Newbie / General discussionsReplies: 0Last Post: 14th Dec 2010, 06:06
  Black screen with audio in all players except WMPBy charliei in forum Software PlayingReplies: 11Last Post: 8th Jun 2009, 19:42
  LCD Screen: video plays on desktop but appearing black on big screen...By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36
  Black screen when playing video files in WMP11 and/or BSPlayer Pro 2.1 !?By Videonator in forum Software PlayingReplies: 8Last Post: 30th Aug 2007, 08:27
  Screen goes black for half a second in Screen Virtuoso avi video stream.By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
