I saw this program that siad it would make the divx video file smaller without loosing quality so i go it. Now it says I have to make the file to two different bit rates. Now I could do this with virtual dub but it won't open divx 4, i guess its too new. Does anyone know how to do this? By the way the compression program is called compressavi.
I dont know compressavi, but normally u use a low and fast motion codec and mix them. DivX4 has no fast and low motion codecs, it is only one codec.
Try Nundub. Nundub combines the fast and low motion codec of DivX 3.11 to get the best results.
By the way DivX4 has a 2-pass VBR.And thats mainly what you search.
TTooLs DVD.Master and MPEG Site
Bit Rates etc....
By Deadmoney in forum Newbie / General discussionsReplies: 7Last Post: 6th Oct 2011, 22:30 -
How can I change the color depth of an AVI file? 32-bit to 24-bit
By evansste in forum Newbie / General discussionsReplies: 0Last Post: 10th Jun 2011, 01:17 -
Adobe Media Encoder h.264 at low bit rates.
By x2x3x2 in forum EditingReplies: 5Last Post: 21st Jul 2010, 18:00 -
Target Bit Rates for HD
By Bman. in forum EditingReplies: 2Last Post: 2nd Oct 2009, 11:01 -
optimal bit rates/codec/frame size for HDV on the web
By lafsunlmtd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 15th Aug 2007, 18:09
