I ordered a JVC GZ MS 110 camcorder. It records MPEG2 so what card is best for me? I just want the best video quality i can get with this cheap camcorder? SD or SDHC I use my old pinicale Studio 9 to edit and burn to dvd I made a lot of good home movies with my old sony hi 8 using studio 9.
Thanks Bob
The HC just means "high capacity". SD cards generally are limited to 2gb. SDHC can handle up to 32gb. First make sure that your camcorder takes SDHC cards, some older ones don't. If it's an HD camcorder, definitely go SDHC as they eat up more memory. Personally, I like to get multiple 4-6 gb SDHC cards. If one goes bad, or you lose it, you didn't lose 32 gb of work. Speed might be more relevant, class 6 would be OK for video.
I love children, girl children... about 16-40
W.C. Fields -
The JVC GZ MS110 is a standard def cam and supports both types of SD. SDHC up to 32GB.
http://camcorder.jvc.com/product.jsp?modelId=MODL028607&pathId=161&page=14Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Compatible problem – SD vs. SDHC card
By coody in forum MediaReplies: 19Last Post: 26th Jul 2013, 11:15 -
Can I use a 30Mbps memory card on a Canon Vixia HF S20 camcorder?
By Willet Vary in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 19th Jan 2011, 01:59 -
Is there any harm in using a class 2 sdhc card in a pocket hd camcorder?
By yoda313 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 23rd Sep 2010, 18:28 -
SD/SDHC Memory Card
By bluemoss in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Nov 2007, 12:28 -
4gb Limit on SDHC Card, FAT32
By AVCHD in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 05:24
