okey, i have spend 4 days learning how make a blu-ray rip and so on, i've used this guide:. i have little problem with size of it, it always is about 4-5gb and bitrate is 881kbps.. so the video is 2h58min long and audio track is 570mb (448kbps). so what is my problem? how can i configure it to be 2-3gb size?Code:http://www.sb-innovation.de/f209/how-create-xvid-brrip-720p-mkv-19364/
why? at under 1000kbps it already sucks badly.
Format : AVI
Format profile : OpenDML
File size : 5.39 GiB
Duration : 2h 58mn
Overall bit rate : 4 329 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 2h 58mn
Bit rate : 2 784 Kbps
Width : 720 pixels
Height : 312 pixels
Display aspect ratio : 4.154
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.517
Stream size : 3.46 GiB (64%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Codec ID/Hint : Microsoft
Duration : 2h 58mn
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 1.91 GiB (35%)
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 500 ms
BRRIP Container Conversion Help
By Cornholio77 in forum Video ConversionReplies: 1Last Post: 28th Dec 2011, 14:41 -
Which is better HD quality or BRRip?
By FaisalKhan in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jul 2011, 09:10 -
Please guide to BRRip
By RoTeMaN in forum Blu-ray RippingReplies: 2Last Post: 19th Aug 2010, 00:28 -
How to do a good BRRip?
By d0ne in forum Blu-ray RippingReplies: 7Last Post: 15th May 2010, 05:29 -
comparison between bluray and brrip
By xenotox in forum Blu-ray RippingReplies: 13Last Post: 24th May 2009, 15:17
