Hi guys!
Ok, here it is the scenario:
I have a series of Japanese anime with Italian subtitles.
In some episodes the subs are out of sync (randomly, not by the same amount of time from one line to the other) so I need to retime them.
Is there a way to do the work within VOBs, without having to demux, converting, remuxing, etc...?
Btw, when I demux I get a .sup file that no software but SubtitleCreator accepts, but it messes up with the colors/position.
How do you work on sup files?
Any help will be appreciated.
Thanks.
Hi Baldrick and thanks for replying.
As a matter of fact I have already tried with DVDSubEdit but it requires to know the amount of delay, which is not constant.
I would need a piece of software allowing a more interactive editing, like Subtitle Workshop.
Another issue is that I haven't quite understood how to deal with those .sup files.
It seems they are "indigestible" to almost all the software I have on my pc. -
DVDSubEdit lets you change the delay for individual subtitles.
It can also open SUP files.
You can open SUP files with SUPviewer and change the times as well; but it doesn't show the video so it isn't that useful to you.
But if you want to do anything more complex, probably you should OCR them to text. Rendered subtitles aren't really meant to be edited. -
Hi AlanHK,
as you said you have to know the delay to work with DVDSubEdit.
I was searching for something allowing to retime the subs "interactively" (i.e. setting start/end time while watching the video).
OCR is a real p.i.t.a. but problem is that even if I go that way I edit a file (let's say a .srt) which I will have to convert to .sup for remuxing.
During this process (.sup -> .srt -> .sup) something messes the colors/position/size of subs. -
Colour/postion size is easy to fix.
Most authoring apps accept SRT subs and you can configure exactly how they will look.
Size, colour, font.
Or use Subtitle Creator, which makes SUP files.
And again, DVDSubedit can change the colours and positions if they're not right after all that.
OCR though requires careful checking. It is never perfect.
Or you could make a rough SRT and see if there is a simple delay you can apply to sync it and apply that to the original SUBS in the VOB files using DVDSubedit. -
I am not very into authoring so I usually do as much work as possible during the demux/remux process.
For some reason I seem not to be able to understand how to use SubtitleCreator properly, I don't feel comfortable with it.
I will try various approaches, hoping to find one that is good for me.
Anyway thanks for your help.
Having problems synching subtitles with VOBs
By somethingcd in forum SubtitleReplies: 0Last Post: 1st Feb 2012, 09:23 -
Edit .vobs easily
By jeff.mikolai in forum EditingReplies: 2Last Post: 22nd May 2009, 05:14 -
Can I edit video_ts.ifo to link missing vobs to DVD?
By Srivas in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2008, 10:39 -
Removing all info from dvd/vobs, but leave raw footage to edit?
By snek11 in forum Authoring (DVD)Replies: 2Last Post: 20th Jun 2008, 09:15 -
VOBs convert to what? to edit in final cut pro...
By tSu in forum EditingReplies: 4Last Post: 16th Nov 2007, 22:07
