how many times has someone, on some forum, posted a question concerning the speed of his/her encoding and someone, supposedly knowledgeable, has chimed in with "the decoder is your bottleneck" or "the filter(s) you are using is/are single threaded" or some similar "observation", usually based on absolutely nothing more than that's what they heard from someone else and just want to feel smart by repeating it.
well, i was bored and decided to run a number of experimental test encodes to see just how much a cpu is working at a given task. fortunately for me, my job was made a lot easier because the latest media coder actually tracks cpu usage of both the encoder and decoder, so with various tests i was able to monitor the cpu load of each to see if a pattern could be discerned.
the test configuration was a phenom 2 x4 620, gts 250 1 gig, 6 gigs ddr2 667, vista 64 bit, media coder 2011 build 5033 x64.
background tasks - utorrent, peerblock, ad aware, avira antivir, avg free, windows firewall, clam antivirus. total cpu usage ~ 10%.
idle gpu usage - 25mb, 0% gpu load, 3% memory controller load, video engine load 0%, as confirmed by gpu-z.
source 1 - mpeg-2 8400 kbps, 16:9, 29.97fps, 720x480p, 6 channel ac3 384 kbps, 48 khz, vob container
audio decoder - mplayer
audio encoder - ffmpeg
video decoder - mencoder
target 1 - x264, 3000 kbps, 16:9, 29.97, 720x480p, 2 channel ac3, 128 kbps, 48 khz, mkv container, preset = ultra fast, 2 b frames, 1 reference frame, tune = normal, main, 4.0
cpu usage decoder - 20% fluctuated between 15% and 25%
cpu usage encoder - 60% flucated between 45% and 70%
total cpu usage - ~ 100%
235 fps
same test, preset = medium
cpu usage decoder - <7%
cpu usage encoder - 90%
total cpu usage - ~100%
45 fps
same test, preset = very slow
cpu usage decoder - .8% - 1.5%
cpu usage encoder - 92% - 97%
9.2 fps
target 2 - same source, xvid, high quality mode, quarter pixel, gmc, medium search, motion est. 6, use assembly optimization = no, sse3/ssse3 disabled, all other as x264 test
cpu usage decoder - .8% to 1.5%
cpu usage encoder - 55% to 70%
total cpu usage - ~70%
8.8 fps
same test, SSE3/SSSE3 enabled
cpu usage decoder - same as above
cpu usage encoder - same as above
total cpu usage - same as above
8.8 fps
same test, assembler optimization = on
cpu usage decoder - 1.5% - 4.5%
cpu usage encoder - 60% - 65%
total cpu usage - 65% - 70%
27.3 fps
same test, sse3/ssse3 and assembler optimization = on
cpu usage encoder - 55% - 65%
total cpu usage - ~ 70%
26-29 fps
target 3 - cuda, main, 4.0, 2 b frames
cpu usage decoder - ~ 20%
cpu usage encoder - ~ 55%
gpu usage encoder - 63%
video engine load - 3%
memory controller load - 3%
gpu memory used 63 mb
total cpu usage - 90%
218 fps
source 2 - vc-1, 11 mb/s, advanced profile, level 3, 1920x1080p, 23.97 fps, ac3, 256 kbps, 2 channel, 48 khz, mkv container
test targets - same as previous tests except target resolution was 1920x1080p and target bit rate was 8 mb/s
x264, ultra fast
cpu usage decoder - 25%
cpu usage encoder - <32%
26 fps
xvid, assembler and sse3/ssse3 enabled
cpu usage decoder - 3% - 5%
cpu usage encoder - <70%
total cpu usage - <80%
5.1 fps
cuda
cpu usage decoder - <29%
cpu usage encoder - 25% - 30%
gpu usage encoder - 32%
video engine load - 0%
memory controller load - 2%
gpu memory used - 113 mb
total cpu usage - <70%
27 fps
so what can we conclude? i think it's obvious that the bottleneck is not in fact the decoder but the encoder, when i standardized all the decoders and simply isolated the encoder the cpu usage of each changed dramatically, and even using more aggressive settings within an encoder changed how much cpu time was used by the decoder. basically it looks like the software decoders we have are capable of feeding data to the encoder as fast as the encoder will accept it, so anyone that tells you that we need gpu powered decoders or that your decoder is the bottleneck, clearly has no idea what he/she/it is talking about.
What "the decoder" is will depend on what file format you are decoding, what software you are using to decode it.
More compressed formats as a general rule require more work to decode.
(Eg, H264 compared with MPEG1).
And similarly to encode; to stream to uncompressed format takes very little power compared with encoding to MKV.
It's not obvious which side filtering should be counsted at either.
Might be better to consider it a separate stage. -
If you are working with uncompressed video the drive may become the bottleneck. And if you stick a slow filter in between a fast decoder and encoder the filter may become the bottleneck. So you have to consider all stages of the pipeline.
in addition to above notes..
don't forget about network spikes, that includes wifi and also including each of the software you listed plus any m$ hidden things running in the background, these all gives spikes in cpu and at different levels. i know when i am capturing, if i forget to turn off my wifi, it get dropped frames at different intervals. when i had my built-in network card turned on in bios my captures would drop frames, same situation. i have to turn it off in bios.background tasks - utorrent, peerblock, ad aware, avira antivir, avg free, windows firewall, clam antivirus. total cpu usage ~ 10%.
-vhelp 5483
Where's the bottleneck?
By dmjerbear in forum Software PlayingReplies: 8Last Post: 30th Apr 2012, 21:03 -
an idea for TRUE video restoration
By unclescoob in forum RestorationReplies: 36Last Post: 5th Apr 2012, 07:57 -
1080p true hd to 720p true hd possible ?
By miss in forum Video ConversionReplies: 2Last Post: 16th Jul 2009, 21:48 -
The real bottleneck?- hard drive?
By orfajackson in forum Newbie / General discussionsReplies: 5Last Post: 3rd Apr 2009, 11:30 -
What is true raw video?
By jeff.mikolai in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2007, 13:20
