i would like to install win 7 64bit on internal 3tb hd.
as my sytem is not supporting uefi boot (asus m2nsli deluxe mobo), i would like to devide 3TB hdd to 3 partitions to see all space on hdd:
1. 100gb system partition
2. 1300gb data partition
3. 1300gb data partition
can i do it like this please? will it work or not? all partitions are less than limit 2tb...will windows 7 will alow me to do it?
Without UEFI a 3TB drive can't be booted, no matter how you partition it. Check out this article at Anandtech, it's nicely explained on "The 2.19TB Barrier" page. Until UEFI arrives, for about the same money you might be better served with a 2TB drive for DATA and a 120GB SSD for system.
Partition HDD
By videobread in forum ComputerReplies: 3Last Post: 16th Dec 2011, 11:22 -
windows 7 64bit and secondary data 3TB HDD not visible in full capacity
By deejay.2001 in forum ComputerReplies: 14Last Post: 21st Jun 2011, 15:08 -
Best summary (so far) on using 3TB HDD
By nic2k4 in forum ComputerReplies: 0Last Post: 17th Mar 2011, 23:31 -
Need help to format and partition a 2TB HDD in half to fat32.
By s-toon in forum ComputerReplies: 4Last Post: 24th Sep 2010, 13:41 -
Problem Formatting Ext HDD Fat32 Partition
By Shaky Jake in forum ComputerReplies: 6Last Post: 3rd Jan 2009, 16:27
