hi,
I've got a mkv file of h.264 and when i use mkvextract gui it's only extracting only 20 MB of the whole video stream which is above 1.75 GB.tried various versions of mkvextract gui ,avi-mux ,yamb but result is still the same.is it the video's problem??.when i tried to demux using xvid4psp it is showing the error NAL too big cannot extract.is there any other h.264 extractor for mkv files.plz help
Results 1 to 14 of 14
i have tried tsmuxer but keep showing the error can't create the temperoary meta file .any other solution plz help
Mediainfo of file
General
Unique ID : 188404013269171282185055390717313268716 (0x8DBD4B0746D1DAF69A28708323D3BBEC)
Complete name : D:\Die Hard Set Box\Die Hard 2 (1990)\Die Hard 2 (1)-003.mkv
Format : Matroska
File size : 1.77 GiB
Duration : 2h 2mn
Overall bit rate : 2 060 Kbps
Encoded date : UTC 2011-02-20 20:06:13
Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') built on Oct 31 2010 21:52:48
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format profile : Main@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 2mn
Bit rate : 2 019 Kbps
Width : 1 280 pixels
Height : 544 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.121
Stream size : 1.73 GiB (98%) -
Try extract with mkvextractgui2 together with latest mkvtoolnix.
You should have the latest builds and disable header compression so uninstall all previous and update, mkvmerge should be 4.5.0 and file>options> disable header removal compression then remux and extarct the tracks with mkvextractGUI2.
yes dvlz mkvtoolnix is 4.5.0 and mkvextractgui(2).i remuxed like u said and extracted and still no luck the extracted file is 20 mb
i don't know wat u mean by corrupted but the file is playing smoothly on all players -
anyway to convert the file to mp4(changing container no re-encoding) without using mkvextractgui
I have not used the MKVextract gui for years. For awhile back then it just didn't work at all. So, I started using MKVcleaver instead.
It may not work any better for you but you asked if there were any other MKV stream extraction tools and this is the only one that I know of.
Tony -
avidemux or xmedia recode, open mkv, under audio and video choose copy. save as mp4.
AutoX264 (Multi Encoder GUI for H.264) v. 0.18 (windows/linux)
By buzzqw in forum LinuxReplies: 143Last Post: 25th Jun 2012, 04:03 -
Problem with MKVextract GUI
By Deathknight in forum Newbie / General discussionsReplies: 1Last Post: 27th Aug 2010, 22:51 -
MKVextract, anyone? (jerky video stream)
By djcv in forum EditingReplies: 4Last Post: 2nd Mar 2010, 15:56 -
Extracting Time Data from Mpeg2 Stream (Hard Disk Cam)
By gallion311 in forum Video ConversionReplies: 2Last Post: 1st Dec 2008, 10:55 -
Extracting motion vectors from MPEG2 Stream.
By anuking in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2007, 11:58
