    Apr 2001
    I am planning on purchasing a combo CD-RW/DVD-ROM drive, and I have a question about ripping from it.
    I understand that all late-model drives can only be region-switched for a maximum of five times before they become locked. I also understand that a Region 1 drive (which is what I will be using) will not play a disc from another region unless it's an "All-Regions" title.
    Having said that, even though it won't play a DVD from a different region without a change, can you still access the files within in order to rip from it, or does this require a region change as well?
    Also, do any of the various rippers convert between video formats--for instance, from PAL to NTSC?
    Any help would be greatly appreciated.
  2. hey. the only stupid question is the one that is never asked!
    and as for region there is a way to get around that. i cant discuss in on these forums but keep your eye open man
    i donno much about dvd-r/rw so i wont guess whether you can still access files on it...but on a hunch i dont think it would...someone on these boards will help you on that subject
