Hi,
Could someone let me know (or link to) the types of HD file formats a PS3 will play?
I see the manual says:
- MP4 file format
- - H.264/MPEG-4 AVC High Profile (AAC LC)
But I'm not sure if that means if I download something like this to my NAS box it will work over DLNA
ViDEO BiTRATE...: x264 @ 11304 Kbps
FRAME RATE......: 23.976 fps
AUDiO 1.........: ENG DTS-CORE 5.1CH 1536 kbps
ASPECT RATiO....: 2.400: 1
RESOLUTiON......: 1920 X 800
FilE SiZE.......: 9.5G
x264 [info]: frame I:1339 Avg QP:18.04 size:204766
x264 [info]: frame P:40889 Avg QP:18.69 size: 91565
x264 [info]: frame B:110440 Avg QP:20.55 size: 45435
It says 'unsupported date' is that related to the filename being a .mkv?
What would be the best way to get to play these on a PS3? Convert to something else? -
If your DLNA can stream it then the container shouldn't matter. I think if you go back a re-read the message it actually says "Unsupported Data", which could mean any number of things. Start with a mediainfo text view of the file in question so we can see how it was encoded. I still think the DTS audio will be an issue.
I simple test would be to set up something like PS3 Media Server on your PC and stream from that. Try transcoding the audio to AC3 instead and see if you get the same message. If so, try trancoding the video as well. It will be hard work with 1080p material unless you have a high-end desktop and an ethernet connection, but it will tell you where the issue lies.Read my blog here.
I've also been recommended this:
http://www.mkv2vob.com/showthread.php?tid=1
Would one have an advantage over the other?
Why do some m2ts files play on PS3 while others in the same format don't?
By chrvi in forum Video ConversionReplies: 7Last Post: 12th Mar 2012, 14:31 -
Can I use my PS2 controller on my PS3 to play PS3 games?
By jbitakis in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 15:24 -
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 08:19 -
MKV to PS3 format help
By badclaw in forum Video ConversionReplies: 4Last Post: 30th Sep 2009, 15:23 -
Video format for PS3
By Jacks_Daddy07 in forum Video ConversionReplies: 2Last Post: 30th Jan 2009, 08:57
