Hello, I'm looking for advice on software for capturing and editing movies. I have been using an old version of Pinnacle Studio but I want to explore other options before deciding whether to upgrade. It would be great if there was an open source option like Gimp is for Photoshop.
Any feedback would be greatly appreciated.
Thanks.
Explain more what you want to do.
If you have time to invest, first master Virtualdub, then AviSynth.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Hi,
If you go to the "Tools" section at the left of the web page and look at the programs available you will see a rating and comment section for each tool.(plus a brief description for each). Make sure your system can use the tools. (you don't have any info on your system which would provide helpful)
Welcome to the site -
I'm nowhere the pro people here are. All I'm looking to do is capture movies from my video camera and create DVDs for friends and family. I want to be able to select scenes and splice them together. I want to be able to inlcude pictures and music in the videos. I want to be able to create menus. I can do all this with Pinnacle Studio but if I can do this with open source I'd rather do that instead of shelling out money.
Thanks -
What is your camcorder model and format? That drives most software choice.
Software isn't free. You pay with learning curve (opensource) or with money (simple to use or cutting edge).Recommends: Kiva.org - Loans that change lives.
I don't mind the learning curve!
I'm surprised that you say the camcorder model drives the software choice. Can you explain why? Right now I have an old Sony Digital 8: DCR-TRV330 but I am hoping to get something else in the near future. What should I be thinking about as I make my decision? -
Opensource: Virtualdub + Cedocida DV Codec over IEEE-1394 import.
VHS will take an alternate capture device $$ needed.Recommends: Kiva.org - Loans that change lives.
Capture Software Recommendations?
By Prince Valiant in forum Capturing and VCRReplies: 19Last Post: 17th Jun 2011, 23:59 -
software recommendations
By deftones in forum EditingReplies: 3Last Post: 12th Nov 2009, 19:33 -
Software Recommendations for Capturing MPEG2
By scienceguy_4 in forum Capturing and VCRReplies: 7Last Post: 4th Oct 2007, 19:59 -
Recommendations for Video Editing software?
By oldcpu in forum LinuxReplies: 10Last Post: 1st Oct 2007, 06:49 -
Looking for software recommendations for newbie
By emiko45 in forum Authoring (DVD)Replies: 3Last Post: 14th Sep 2007, 17:29
