I have suddenly lost the ability to use an Avisynth script to open an .flv file with virtualdub. It says "no combination of filters could be found to render the stream.". This never started happening until just now, and I have made no major changes to my computer since it was working.
DaneClark, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
What source filter are you using to open the .flv file in your Avisynth script?
DirectShowSource will require appropriate DirectShow file splitters and codecs to be present on your system.
ffmpegSource uses its own file splitter and codecs.
Try switching from one to the other.
Do you have a problem with all .flv files, or only certain ones?
If the latter, post a MediaInfo report on the problem file. -
First quote your entire AVS script so we can know what you're trying to do.
But I guess you're using DirectShowSource
That means it uses Windows codecs to try to open the file.
You might try ffmpegsource2
http://ffmpegsource.googlecode.com/svn/trunk/doc/ffms2-avisynth.html
Once you've installed that, and FFMS2.avsi, you can open just about anything using
FFmpegSource2("file.whatever",atrack=-1) -
this is great, i had trouble opening mpegs (from YT d/l's of pizza dough receps) and they wouldn't open, didn't realize i needed the haali splitter, so i d/l and installed, and all files open now, thanks..only problem i have is some of these flv files audio plays in slow pitch, (monster sound) .. i'm sure i'll figure and resolve it. [resolved: no param for ffmpegsource for pitch, so i remux with ffmpeg SVN-r24489, no more monster sound]
now all we need is a tool that, accepts a drag/drop of A/V file, open in your favorite template script, set up filetype (ie flv, mpeg, avi) then shoots into your favorite timeline--all this should be transparent and quick. course, as always, i tweak the scripts in-between folder/file hunting hops. doing this for years and am tired now.
-vhelp 5480Last edited by vhelp; 20th Feb 2011 at 13:49.
Can't open FLV with Avisynth
By Greensmurfet in forum Video ConversionReplies: 1Last Post: 21st Oct 2011, 18:00 -
AviSynth open failure in VirtualDub
By fatcharlie in forum Newbie / General discussionsReplies: 5Last Post: 3rd Mar 2011, 21:32 -
can't open flv in VirtualDub
By shun in forum Video ConversionReplies: 3Last Post: 26th Jul 2010, 18:10 -
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 21:48 -
How to open a small flv file in virtualdub?
By Wizard81 in forum EditingReplies: 4Last Post: 20th Nov 2009, 12:14
