Hey,
I posted this thread (https://forum.videohelp.com/threads/331977-avi-files-that-won-t-work-correctly!) in the newbie-forum and got some help. Ended up redirecting me here though.
Any help would be greatly appreciated.
Results 1 to 11 of 11
Might you have any short clip you can upload so we can try a few tools on our own? Then, if we find an answer, we can announce it here. I can run through twenty different apps in the time it takes to compose a few suggestions here.
I just took a look at the original thread you linked in your first message. Have you installed Apple's MPEG2 codec? It looks like your footage is MPEG2 and that may be the issue. EyeTV records in MPEG2 so, if you have that app, try to open the footage there (if you don't have Apple's MPEG2 codec).
pixel zombie: VLC gives me choppy video with horisontal lines and choppy left channel sound. Haven't tried mplayer.
16mmJunkie: With what software? No program in which I know how to perform that task (MPEG Streamclip, Compressor, VLC) work. -
Try using ffmpegx. Drag/drop one of the files onto ffmpegx's open window and see if you can transcode it
to .DV stream. IF it is successful, you then have a mac compatible file you can edit with in
iMovie, FCE, or FCP. If not ffmpegx, then try Visualhub, which works on ffmepg backend.
if this isn't successful, the only way we can be of further help is to get
a copy of one of the offending files to work with.
I would try somehow to get one of the smallest of the problem files uploaded
to megaupload.com or somewhere you can share large files.
Barring that, we won't be able to help.
In the future, try to remember that FCP loves DV Stream files,
and had you recorded to that format in Adobe Premiere while on the "set",
you wouldn't be having the cross platform problems you are having now.
Premiere= .avi files
FCP /FCE/iMovie = DV Stream files
You only recourse may be to take the files back to the "set", use their setup with Adobe PRemiere,
and edit there. OR, take the files back to the set, use their Premiere setup, and re-export the files
out as DV Stream files. ( in premiere DV-AVI)."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
FLV won't play correctly in another computer
By kfain in forum Video ConversionReplies: 6Last Post: 29th Dec 2011, 13:10 -
DV won't play correctly anymore.
By xtremeD63 in forum Software PlayingReplies: 52Last Post: 9th Apr 2011, 14:08 -
.avi files that won't work correctly!
By RolloSwe in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 17:41 -
What is a good AVI joiner (freeware I hope) for when VDub won't work??
By Lolipop Jones in forum Newbie / General discussionsReplies: 1Last Post: 5th Jan 2010, 10:52 -
m2t files won't work in Vegas Pro 8
By Patokid in forum Newbie / General discussionsReplies: 12Last Post: 21st Jan 2009, 15:47
Nothing changed.
