Help, I bought a dvd, phar lap from Autralian ebayer, It is PAL . My dvd player wont play it. Does anyone have the region codes for my player![]()
Even if a region code hack existed you would still need to convert the PAL video format to NTSC video format.
If you want to watch the DVD on a PC you can install the VLC media player. It's in our Tools section. It's freeware and it doesn't check region codes. PCs don't care about PAL/NTSC playback issues unlike standalone DVD players.
You can rip the DVD to your hard drive and re-burn to a new disc. That would remove the region coding. But as hech54 points out your DVD player may not play PAL video at all and you'd be stuck if that's the case. We have guides on PAL->NTSC conversions but I'll warn you that in general they take a lot of time to do and you may not be very satisfied with the final result (ghosting and unnatural motion issues are possible, plus you'll lose all the menus with a conversion). The quickest and best way to watch the DVD is to use VLC on a PC.
Sansui VRDVD4005 Recorder
By Lindon in forum Newbie / General discussionsReplies: 0Last Post: 4th Dec 2011, 11:10 -
Unlock code for Sansui DVP 1011
By frank271 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jun 2009, 17:12 -
Sansui DV-X3030
By rap8557 in forum Newbie / General discussionsReplies: 1Last Post: 24th Apr 2008, 09:53 -
VRDVD4005 Sansui
By PPAABB in forum Newbie / General discussionsReplies: 0Last Post: 4th Oct 2007, 11:21 -
samsung or sansui
By gunukhan in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Jul 2007, 13:20
