I have the latest version 1.3.12 (beta) installed. I would like to capture audio off the air for a radio station I'm listening to on my PC. I've gone to Preferences and see no devices (found) available for recording. How do I get going on my little project?
See Mixer_Toolbar_Issues#Windows_Vista_.2F_Windows_7
The most recent Windows operating systems called Vista and Windows 7 treat individual recording sources such as line-in, microphone and "stereo mix" as recording devices in their own right. As a result, the Mixer Toolbar input selector will be always be greyed out by default. Some users report that input sources can be made to appear in the input selector by running Audacity in compatibility mode for Windows XP. To do this, right-click over audacity.exe in Windows Explorer, then click Properties, then the "Compatibility" tab. This isn't a generally recommended solution.
Instead, select recording inputs at Edit > Preferences: Audio I/O tab, in the "Recording Device" dropdown (this dropdown is in the "Devices" tab in Audacity Beta). Also in the Beta version, recording devices can be viewed instead in Device Toolbar. To enable this toolbar, click View > Toolbars > Device Toolbar. Here is an example of recording inputs in Preferences for two different physical devices (an inbuilt sound device and an external USB sound card):
Microphone: Realtek HD Device
Line-In: Realtek HD Device
Microphone: USB Audio
Line-In: USB Audio
Stereo Mix: USB Audio
If selecting a particular input does not work, or you don't see the input you want, try selecting it in the Windows Control Panel (see the next section below).
We strongly suggest you read our further information about Windows Vista and Windows 7. -
Thanks. Unfortunately, I don't see any Audio tab. Nor do I find anything useful in the Device Toolbar under Preferences. All I see is a list on the left: Interfaces-Devices, Playback, Recording, Quality ... Devices shows Host: MME, Playback-Device: Headphones and Recording-Device: No devices found.
I'm going to punt on this one. I found my trusty old Pogo Radio device, which allows me to record on Line with an audio cable. -
Usually you select "What you hear" or "Stereo Mix" but not all PC's with onboard audio(read laptops) allow it, if you have Vista or 7 you have to enable it with a secret hack.
http://www.hardwareheaven.com/audio-general-technical-discussion/130879-windows-vista-...-hear-how.html
rant: I have several old PC's(pre-2006) and thay all allow recording "what I hear", it seems somebody wants to close the analog hole.Last edited by MOVIEGEEK; 18th Feb 2011 at 17:09.
Actually there are ways to capture Internet radio streams directly.
Eg Tapin http://tapinradio.com/wp/
which plays and can record most Internet radio streams (except for Real Audio).
If it's an MP3 stream, it just records it as-is.
Or Streambox VCR Suite.
Just Google for "Stream capture" and you'll find plenty of other apps.
If you capture the stream, rather than the audio outout, you get a cleaner sound and you don't get interruptions if there is buffering.
Sometimes you have to use a URL sniffer to find the actual address of the stream if they use some kind of flash player, for instance. Tapin has a lot of those in its presets already.Last edited by AlanHK; 18th Feb 2011 at 20:38.
AUDACITY - Records ONLY from MIC , on HP Laptop Win 7
By mrlewp in forum AudioReplies: 0Last Post: 12th Jan 2011, 21:54 -
Audacity help
By efiste2 in forum AudioReplies: 3Last Post: 5th Aug 2010, 13:59 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
Win 7 and XP dual boot issues. Can't access one of the drives in Win 7?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 13th Jun 2009, 22:51 -
need some help with audacity
By shashgo in forum AudioReplies: 7Last Post: 16th Jan 2009, 01:21
