I first thought this was player related. I've now installed FFDShow etc. Tried several different codecs. Loaded CCCP etc. Nothing helps.
Basically I can play back anything on my HTPC except with MP4 files the audio is garbled/white noise etc.
I can play back MKV files in full 5.1 or DTS.
I tried to convert a file from MP4 to MKV and the audio issue followed the new file.
I am out of ideas.
Can anyone help?
Thanks in advance.
	Are you running windows 7? Then disable the built in mp4 decoder with preferred filter tweaker.
	That might be a possibility but wouldn't the video be corrupted upon conversion also? It seems like most converters that don't copy in realtime while playing back the video will simply spit out a corrupted file that is unwatchable and unlistenable (is that a word?).
 To the poster - did the original mp4 files play correctly at all at any time? Do they play on a portable media player or an external player like a wdtv player? They may have to be reencoded from the original sources if they are corrupted on any playback device. Try to determine if they can be played properly at all on any system first.
 Edit - this is assuming the mp4 files have video content of course. They could be purchased audio files in which case the normal conversion methods wouldn't work except for realtime audio copying while playing - since most past cracking methods have long since been countered by the distributors.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
  MPEG StreamClip - H.264 MP4 w/AC3 audio loses audioBy the_wallcrawler in forum Video ConversionReplies: 5Last Post: 25th Jan 2014, 04:05
  MP4 w/ AAC ---> MP4 w/Compatible AudioBy NotSoEasy in forum Newbie / General discussionsReplies: 3Last Post: 26th Aug 2011, 16:41
  trouble with audio after appending a .jpg turned .mp4 to another .mp4By canadianjameson in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2011, 10:55
  mp4 to mp4 and keep original audioBy jntaylor63 in forum Video ConversionReplies: 3Last Post: 24th Mar 2009, 14:16
  Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
