Hi-
I recently installed VDub. Great program. How do you get existing codecs, in my case Divx, to show up in the compression window? It is installed on my system and I'm on a Win7/64b system if that makes any difference.
Thanks,
Mark
If you are using 64 bit VirtualDub you need to install 64 bit codecs. If you use 32 bit VirtualDub you need to install 32 bit codecs. The two systems are separate. You need VFW codecs for VirtualDub. There's really no advantage in using the 64 bit version of VirtualDub. It has more bugs and there are fewer 64 bit filters and codecs available for it.
Add Codecs Column to Details in XP
By DarrellS in forum ComputerReplies: 27Last Post: 20th May 2014, 13:56 -
How Can I Add Codecs to Pinnacle Studio 12?
By slalomchip in forum EditingReplies: 6Last Post: 7th Sep 2011, 20:47 -
VDub "add to job control" option...not there anymore?
By CursedLemon in forum EditingReplies: 2Last Post: 17th Nov 2009, 10:47 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
2 xvids codecs in vdub
By catdaddio6 in forum Video ConversionReplies: 1Last Post: 26th Aug 2008, 16:29
