I set up a webcam to take pictures of the ocean in back of my house every 5 minutes over the course of a day. I'd like to take those and assemble an 18-hour video.
Are there any codecs that can assemble ~300 JPGs into a 18-hour video file under a gig? (a framerate way below 1 fps, I suppose)
If so, is there software that I can use to assemble such a video?
Thanks in advance,
Aidan
AVISynth can do this. Read up on "imagesequence", which can assemble a movie from still pictures. Once you have learned how to do this, view your results using VirtualDub. From VD, you can export an .AVI movie, or frameserve via AVISynth to an MPEG encoder.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
I'd do it as a slideshow instead, which is essentially what it is.
Many DVD players will do this from just a disk full of images. -
If they're sequentially numbered VirtualDub can open them in one swoop and save as AVI with whatever frame rate you want. Yes, you can set the frame rate to 1/300 fps (one frame every five minutes).
Vegas Movie Studio opens them in one swoop too, and they come in to the project as a single video.
VirtualDub worked great, thanks all!
(side question: anyone know a digital photo frame that can play a 180MB AVI file?) -
That's how big the finished file was? That seems awful big for a 300 frame AVI. I just created a DivX AVI from 140 jpegs at .003 fps that was 1.36 MB in size. The clip is 12 hours and 58 minutes long and the resolution is 720x404.
Yes, VirtualDub will save as uncompressed RGB if you don't select a compression codec. Try installing the Xvid codec and saving with Target Quantizer 2. That will be virtually indistinguishable from the source but give you a much smaller file.
Looking for jpg to video with special needs
By rbur in forum EditingReplies: 3Last Post: 13th Jan 2012, 02:12 -
Video like a JPG slideshow
By ranosb in forum Newbie / General discussionsReplies: 9Last Post: 11th Jul 2009, 18:38 -
JPG to AVI Back to JPG is it possible?
By concisa in forum Video ConversionReplies: 3Last Post: 11th Apr 2009, 10:06 -
Extracting jpg frames from Video files
By wrazoru in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2008, 06:08 -
AVCHD the new MP3/JPG of video?
By PuzZLeR in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2008, 20:00
