Hi
I Just installed
Panasonic TV - TC-L32C22
and
DYNEX DVD Player - DX-UPDVD2
Cable box is Verizon FIOS
TV, DVD, and Cable Box all have HDMI
I would like to use one remote only
Panasonic has a feature called Viera link that is supposed to recognize compatible HDMI devices
Also, Panasonic remote has features (INPUT and FORMAT) that I will need to use. - FORMAT allows me to adjust the image from widescreed to 4:3
The Dynex player is basic, and the only special features I intend to use is SUBTITLES
The Panasonic remote does not seem to recognize the DYNEX dvd player
Can anyone suggest what I should do to get to a single remote -
1. Can I use the Panasonic TV remote to work the FIOS cable box?
2. Can I use the Panasonic TV remote to work the DYNEX dvd player?
3. Is there a universal remote that will work all three?
I want to keep the TV. I would return the DYNEX dvd player if necessary. I paid approx $35 for it.
Any help would be appreciated
Thx
The "vieara link" is just Panasonic's brand name for the HDMI interoperation feature nearly all televisions now have. The actual usefulness of the "link" is debatable: I have disabled it on all my sets because it generally gets in the way. Its fine if you have VERY simple needs, like wanting your disc player, FiOS box and TV to all power on at the same time. But things get tricky after that: the remote and television interact with the devices in unpredictable combinations that often run counter to what you want.
Its better to get a good separate universal remote with a "learning" function that can copy the the signals from all your other remotes: this way you can choose which button does what in a way thats most convenient for you. Sony used to sell the excellent RM-VL600 remote for about $25, I haven't seen it lately so there may be a newer model. Look for it, or something with similar features like "learning" ability, letting you choose among 6-8 banks (allowing all buttons to cover each box you own), and offering some "combo" buttons that can be programmed to work like the Viera feature (such as turning all your home theater gear on at once, and switching the TV input to your most-used device, at the press of one button). Programming the buttons can take an hour or two, but it pays off in having a custom remote that suits your needs. Some folks even spring for ultra-luxe remotes like the Harmony series, but I think $79-$179 for a remote is overkill when you can get similar features for $30 on a less-fancy-looking knockoff. -
Thanks Orsetto
You confirmed my concerns that what I think is simple is probably complex. I will take your advice and go for a separate universal remote. I have heard that iphone apps are getting better as universal remotes.
Do you know anything about these? Is it just another can of worms or do they work?
Thx
Zumata -
I haven't tried the "use your phone as a remote" apps yet, so far I hear good things and bad things. It probably depends on what you need it to do: if it works for you you'll love it, if not you'll post complaints. If you can test drive some phone apps at reasonable cost, its certainly worth a shot: please post back here with your experience.
DYNEX not compatible
Returned it and Bought SONY instead - also not compatible
Sony's system is Bravia Link. Panasonic's is Viera Link
Tech support at both Sony and Panasonic say that only way to check compatibility is plug in and see what happens.
Seems that only way to get Link function on a DVD is to spring for more than $200 which is out of price range for what I want.
Also, Looked into HDMI a bit more - seems that HDMI cable does not carry signal for CAPTIONS on DVD videos which is important feature for me.
So - I think I am back to 3 remotes - Thx for help anyway.
Which format for panasonic viera TV
By kode in forum DVB / IPTVReplies: 47Last Post: 14th May 2014, 11:31 -
panasonic viera xseries mp4 porblem
By bensonoommen in forum Video ConversionReplies: 3Last Post: 17th Feb 2012, 13:52 -
Panasonic Viera TX-P42UT30B - MKV Playback issues
By nathan1990 in forum DVB / IPTVReplies: 2Last Post: 20th Dec 2011, 06:25 -
SD card for panasonic viera
By gamergaz in forum Capturing and VCRReplies: 7Last Post: 25th Nov 2011, 20:31 -
Panasonic Viera TX50V20 TV will not play AVCHD
By dobien in forum Newbie / General discussionsReplies: 5Last Post: 19th Jul 2011, 10:47
