I was trying to back up a band of brothers br dvd and the above message appeared. What should be my next step?
Results 1 to 9 of 9
Try something different. Since you provided no information on what software and settings you were using it's hard to give you specific suggestions.
IT IS A BLU RAY DISC. I WAS USING THE LATEST VERSION OF BD REBUILDER THE FOLLOWING IS FROM THE INSPECT.EXE
- Windows Version: 6.1 [7600]
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: Not installed
- FFDSHOW: 3744, not recommended version
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- BD Rebuilder v0.37.0.5, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok -
I AM USING ANYDVD LATEST VERSION TO DECRYPT
THE FOLLOWING IS THE LOG FROM BDRB
[09:38:55] BD Rebuilder v0.37.05 (beta)
- Source: BAND_OF_BROTHERS_D1
- Input BD size: 31.65 GB
- Approximate total content: [02:19:24.272]
- Target BD size: 22.95 GB
- Auto Quality: Good (Very Fast), ABR
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[09:38:55] PHASE ONE, Encoding
- [09:38:55] Extracting A/V streams [VID_00004]
- [09:39:13] Reencoding: VID_00004 (1 of 12)
- [09:39:13] Collecting video information
- Source Video: VC-1, 1920x1080
- Rate/Length: 29.970fps, 1,319 frames
- [09:39:13] Reencoding: VID_00004, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.37.05 (beta)
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[09:39:20] - Failed video encode, aborted -
THANK YOU FOR ASKING FOR THE ADDITIONAL INFORMATION, ESPECIALLY THE INSPECT.EXE LOG. I DID NOT KNOW THAT IT WAS PART OF BDRB. AFTER POSTING IT I STARTED READING IT LINE BY LINE AND DISCOVERED THAT I NEEDED TO UPDATE ONE PROGRAM TO THE LATEST VERSION AND ALSO INSTALL ANOTHER. AFTER HAVING DONE THAT EVERYTHING WORKED FINE. THANKS AGAIN FOR HELPING A REAL NEWBIE.
BD Rebuilder: ERROR "failed video encode, aborted"
By jlm86 in forum Blu-ray RippingReplies: 1Last Post: 22nd Feb 2011, 18:57 -
BD Rebuilder v0.34.11 Failed video encode, aborted
By jairtonfs in forum Blu-ray RippingReplies: 3Last Post: 7th Oct 2010, 12:08 -
"Failed to read video frame"
By jva1254 in forum EditingReplies: 1Last Post: 25th Sep 2009, 05:59 -
"DVD-Video files reallocation failed"
By alegator in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2008, 10:26 -
ATI AIW 9600XT, "TV failed to initialize the video" problem...
By etecnifibre in forum Capturing and VCRReplies: 11Last Post: 20th May 2008, 15:08
